SharkAttak
is there a difference in gearing from the 06' to the 07', also, what is the gearing in the attak compaired to the apex, which is faster
AIRWOLF
Guest
07 rtx is geared lower it has
2007 rtx 22t top gear
2006 24t top gear
2006 24t top gear
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
- None, looking now!
Tha 2006 Attack has a 23t top gear. I had baught this gear from Ulmer for my 06 RTX.
-1CS
-1CS
yamstock1
1CrazySledder said:Tha 2006 Attack has a 23t top gear. I had baught this gear from Ulmer for my 06 RTX.
-1CS
Have you already tried your Apex with the 23??? That's what I put on my 07 Apex... I'm anxious to try it......
agaguk
Hey yamstock1 i've just installed 23/37 on my '07 rtx and i kept the same chain (68L)it's gonna be way faster than the stock gearing 22/38. i can't wait to try it maybe at the cabanon at the end of november...
Wartsnuff
agaguk said:Hey yamstock1 i've just installed 23/37 on my '07 rtx and i kept the same chain (68L)it's gonna be way faster than the stock gearing 22/38. i can't wait to try it maybe at the cabanon at the end of november...
I have been talking to my dealer about this, and he says he thinks your full shift of your transmission sheaves will not happen ????
any thoughts u guys ?
yamstock1
Ok, what I have on mine is 23-38...... and yes, I will try it at the Cabanon as soon as the lake will freeze.......
if stock gearing is 22/38 and u went to 23/37,i could be wrong but would that be basically the same as stock..u went up on top and down on bottom,did he not cancell both out....
SledFreak
- Feb 7, 2005
- Ontario. Canada
Red800, That's what I would think.... Yamstock1, will have the bigger change.
agaguk
you're wrong red800 the top gear gear is the drive gear and the bottom gear is the driven gear as for the clutchs whe your secondary clutch open and the belt going down you increase your speed. so the bottom gear is driven when you going down one tooth you increase your speed. 23/37 is the tallest gearing if you want to keep the stock 68 links chain as found on the '07 rtx...
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
22/38 = 1.73:1 ratio
23/37 = 1.61:1 ratio
23/38 = 1.65:1 ratio
Generally for ever 1 tooth on the top gear is generally worth close to 2 teeth on the bottom gear.
Examples:
24/38 = 1.58:1 ratio
24/40 = 1.67:1 ratio
Examples:
snolover
- Dec 1, 2004
gearing
Yamstock i think your on the good way with 23/38
Winter is coming soon
let it snow let it snow let it snow
1CrazySledder
- Aug 11, 2005
- Cartersville, GA.
yamstock1 said:1CrazySledder said:Tha 2006 Attack has a 23t top gear. I had baught this gear from Ulmer for my 06 RTX.
-1CS
I haven't even installed it yet. I'm in the middle of putting my 136" Expert in and the tunnel ext. and a few other things. I'll install the gear when I change out the tracks. I should get going on this stuff, only 1 month left before trails here in WI can open.
-1CS
Here's a link to a gearing chart from MPI (scroll down about half a page
http://www.mountainperformance.com/yama ... _chain.htm
SledFreak
- Feb 7, 2005
- Ontario. Canada
So you geared it taller..... What makes you think it can pull it and how much more top end are you going to have?agaguk said:you're wrong red800 the top gear gear is the drive gear and the bottom gear is the driven gear as for the clutchs whe your secondary clutch open and the belt going down you increase your speed. so the bottom gear is driven when you going down one tooth you increase your speed. 23/37 is the tallest gearing if you want to keep the stock 68 links chain as found on the '07 rtx...
