y_guy
- Feb 22, 2005
Asking for help with diagnosis. 2009 GT runs well most of the time, but sometimes she seems to load up on gas and it won't idle. Just shuts down.
Oil just changed, i thought maybe too much oil was put in but it checks out. Injectors and coil check out fine. Any ideas?
Wiring issues? please help.
Grimm
- Apr 15, 2005
- Ottawa, Ontario
- 2018 MXZ 850
Spark plugs?
y_guy
- Feb 22, 2005
no, they were new at oil change.
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Inspect the check valve for the fuel return to the tank. I've seen these plug and not allow fuel back to the tank which increases fuel pressure and makes sled load up.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
See if your fuel retun line flows freely back to the tank. There is a check valve on the tank that some times sticks giving you a rich condition.
Is this just when idling or when riding it?
y_guy
- Feb 22, 2005
You can run it hard and it seems to run just fine... But when you come down to idle is will die and you smell gas.
- 12K
- 12K
