The sled I bought was setup to run 10-12lbs, but I don't care to run race fuel all the time like the previous owner did. So I'm setting it back up to the original 5-6lbs. Unless I can get away with a bit more? Changed ignition to PCV-PTI and added the ignition module. I read somewhere to pull 1 degree per 1lbs? Would like to run as much as possible on pump with no shim. Is 8 safe, or should I stick to 5-6? Also is there a special way to reinstall the pulleys so the are aligned correctly? looked like they weren't completly parrallel with each other before I pulled them off.
Sent from my SM-N910V using Tapatalk
