Blown14psi
Anyone know of a way to increase the rev limiter without a tuner?
SharkAttak
why would you want to do it?
Blown14psi
I want to be able to run around 11500 to 11800 on the bottle.
I wonder if the stock fuel system is mapped that high?
RacerDave
What rpm does the limter kick in at? does it stutter the ignition then?
Blown14psi
ricerocket said:What rpm does the limter kick in at? does it stutter the ignition then?
I was told 11200 but on the tach it reads 11500. I was told that the ECU cuts spark but not fuel. That would explain the popping exhaust when I hit the limiter.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
11,200 every tach may read a little different. The ECU interupts the ignitioin.
