fourndog
Any of you guys having a problem with the reverse being out of adjustment on you apex? If you are what is the adjustment procedure?
waspolarisowner
I have an Attak that has been back to the dealer 3 times for the reverse grinding, locking up. Not happy.
turbowoz
Adjusting Step 1 - Upper Linkage
Loosen locknuts and set the length between the locknuts to 27 mm
Tighten locknuts
Adjusting Step 2- Rear Lower Linkage
Loosen locknuts
Turn the threaded adjuster to decrease distance between locknuts
until freeplay is removed, then turn threaded adjuster back 1/4 turn.
Tighten locknuts
Adjusting steps as per Yamaha Tech Tips
Tighten locknuts
Loosen locknuts
Tighten locknuts
fourndog
Nice! thank you turbowoz
AIRWOLF
Guest
turbowoz said:Adjusting Step 1 - Upper Linkage
Tighten locknuts
Loosen locknuts
Tighten locknuts
this sould be posted in the FAQ section for future reference
Nice Rumble
Also keep in mind this is a constant mesh gear not syncromesh so sometimes it won't want to go into gear. Just move forward or backward a foot or so and it should go into gear.
1bad442
Yes, I'm having that problem. Reverse pops out under any throttle input and makes a horrible grinding sound. Dealer said he'd fix it.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Mine did it until it got adjusted on my boys rtx,and today woodys performance told me how to adjust it,for any future slippage,than he said that that awful sounding of gears grinding,he said was really nothing to worrie about,as he said that the gears are very stout and it just sounds worse than it really is,and if you cant or wont adjust it on the trails,and you still want to use it,pull it into reverse and just hold onto it,until you are finished backing up..1bad442 said:Yes, I'm having that problem. Reverse pops out under any throttle input and makes a horrible grinding sound. Dealer said he'd fix it.
