Jonesynl
- Nov 6, 2014
- Roberts Arm, Newfoundland, Canada
- 2008 Apex MTX SE
We all know the apex running boards suck for deep powder and always ice up and get slippery, anyone runing better boards? Wrp boards? Any others ? Was going to buy some RSI boards for a nytro mtx and see if I could fit them to my apex. Someone give me some guidance
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
What about the toothy Yamaha tunnel reinforcements, would that help? Easy add-on.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
What are you doing with in constant deep powder with the Apex? Not the right machine...
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Ah MTX I missed that part!
Jonesynl
- Nov 6, 2014
- 2008 Apex MTX SE
I use this forums because theres never one one active on the apex mountain forum :/
mysledblows
- Jan 23, 2007
- Central MN
- Sidewinder, mcx phazer, phazer, apex
- Jenkins, MN
I put a set of better boards in mine. Not ideal with the heat exchangers running under the boards like they do, but at least now there is a chance that the snow falls out and what doesn't melts off faster.
TBay Sledhead
- Jan 16, 2005
- Thunder Bay, Ontario.Ca
- 06 Attak
01 SXR Long Track
What boards did you use?I put a set of better boards in mine. Not ideal with the heat exchangers running under the boards like they do, but at least now there is a chance that the snow falls out and what doesn't melts off faster.
mysledblows
- Jan 23, 2007
- Central MN
- Jenkins, MN
snowmobilebetterboards.com
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
Where can I get these????What about the toothy Yamaha tunnel reinforcements, would that help? Easy add-on.View attachment 104177
gitrdun
- Mar 15, 2007
- north of superior
- 07 Attak
Go to Yamahamotorsports.com, Snowmobile accessories, 2011 Apex (but same fit all the way back to 2006), Gripper tunnel reinforcements, SMA-8HG58-MT-00 for the black ones, SMA-8HG58-SL-00 for silver. About 137.00. If you have the dial adjuster on the drivers side(like in the picture) you just have to trim the dial adjuster plate to make it fit nice.
icebreaker
- Aug 18, 2010
- 2011 xtx
Ok thanks!!!!Go to Yamahamotorsports.com, Snowmobile accessories, 2011 Apex (but same fit all the way back to 2006), Gripper tunnel reinforcements, SMA-8HG58-MT-00 for the black ones, SMA-8HG58-SL-00 for silver. About 137.00. If you have the dial adjuster on the drivers side(like in the picture) you just have to trim the dial adjuster plate to make it fit nice.
