jlratz
Does anyone know if the 2017 APEX tuner ski's will fit a 2015 Apex. They have different part numbers?
darv
- Aug 9, 2005
- International Falls,minnesota
- 08 Apex 40th LTX
yes they will fit but buy some other ski's C &A or other brands better skis. that mine opinion. i run C&A razors with shims and it rails. on mine
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Put snow trackers on stock Ape ski's. Cheap, last long long time & will utterly surprise you! I'm not sure what "utterly" means, but they are AWSOME!
stevewithOCD
- Jan 1, 2008
- 900 R
2006 Apex RTX
To answer your question, yes they fit. But WHY? I think everybody took them off so you should be able to find a cheap pair
Teamblue4
- Feb 20, 2008
- Il.
- 2012 Apex XTX
2013 Apex SE
2014 Apex SE
2014 Apex XTX
Yes they will fit, Tuner ski's are awesome. (IMO)
Winderallday!
I believe in 17 they came with Tuner 3's and in 15 were Tuner 2's, not sure what the difference is, but likely the reason for the different part numbers.
I couldn't get the tuners on my 15 Apex to work for me period, (pushed and darted like crazy), so I went back to the pre-tuner Apex ski that was on the 2011+. I have run both Aggressive Snowtrackers and Cobra Head carbides on the 11+ skis and had good success with both.
Each rider has different expectations, so to each his own on the Tuners.
Cheers.
whitedust1
Agree ditch the tuners buy 2012 -2011 single keel stockers skis put on aggressive snowtrackers and rail the trails. Stockers not expensive skis at all.I believe in 17 they came with Tuner 3's and in 15 were Tuner 2's, not sure what the difference is, but likely the reason for the different part numbers.
Cheers.
thor452
Because I can
- Jan 5, 2010
- Shawano,WI 54166
X10Agree ditch the tuners buy 2012 -2011 single keel stockers skis put on aggressive snowtrackers and rail the trails. Stockers not expensive skis at all.
budman 1000
- Jan 22, 2010
- Saskatchewan
- 2023 Yamaha LTX GT, 2017 Sidewinder XTX LE 137; 2015 Apex xtx, 2010 Nytro xtx turbo, 2008 nytro rtx, 2005 RS Vector MTN turbo
my 2011 apex xtx railed corners with the stock ski and had pretty good bite cornering in soft snow also. that 2011 ski had very little darting also. My 2015 apex xtx with the tuners sucked big time, only nice thing about tuners is there cheap and work ok if your on well packed groomed trail. if you really want tuners on an apex I recommend the 150mm tuner as its 6 inch's wide verses 5.25 inches and put on snow trackers or a similar setup
