apracing
- Feb 19, 2013
- new brunswick
- 2004 rx1 warrior 2006 apex gt 1979 enticer 340
Can i install a apex suspension in my rx1 without any issues.. both are 136 skids .can I bolt up the front and rear the same ??
Fortress
All Yamaha skids are very similar, just measure it all out....at the very least you can use apex rear shock on rx1 skid if you drill new holes on skid.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Yes you can, my friend! There are many on here that have made the upgrade to a mono, including myself. Link below:Can i install a apex suspension in my rx1 without any issues.. both are 136 skids .can I bolt up the front and rear the same ??
http://ty4stroke.com/threads/2004-warrior-re-build-upgraded-to-136-mono-and-much-much-more.138024/
A mono and Pro Action have different mounting points. I would recommend contacting Barn of Parts and talking to Travis. He is a TY vendor and can set you up with a kit to retrofit a mono directly into your sled.
http://www.barnofparts.com/suspension-mounting-plates
Redbeard
- Oct 14, 2011
- IN
apracing, while you're at it; inquire with Travis about the dual rate spring he offers for the mono shock. I've read lots of positive results about this spring, and it's priced right too!
Skeeter
I have done this upgrade on both the front and rear suspension (plus lots of other modifications). I used the mounting plate from Barn of Parts to switch to the mono rear suspension. The plate is used to locate the new mounting position for the front bolts. On my 121 inch the rear mounting holes were the same. I also installed the progressive rear suspension spring. BEST MONEY I SPENT ON THE SLED! The rear suspension does not bottom out now with the progressive spring. Contact Travis at Barn of Parts and he will help you out. Great fellow to deal with....Can i install a apex suspension in my rx1 without any issues.. both are 136 skids .can I bolt up the front and rear the same ??
