JERSEYJOE
Does anyone have a wide kit on their APEX? I have installed one on my 06 GT and want to set up the suspension front and rear. Currently the A Arms are parallel with the ground ( lowered spring), the limiter is up one hole, has revalved Pioneer shock with BIG BOY spring.
also has 13 mm sway bar, Micro Belmont drive axle with extro drivers
Front sounds about right... as far as the rear... basically you should ride it and tell us what you feel and how it handles...start with Pioneers settings.
nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'm really curious as to how much of a difference the wide kit makes on the Apex. That is something I've considered doing for a number of years now but haven't been able to pull the trigger on for the $500 or $600 it will cost.
s fortuna
- Oct 23, 2014
- 02 venture 11 apex se
once u have a great suspention , u will wonder how u did without it ,like my venture , ohlins front , m20 adjust on the fly rear , cost about 3k but then u dont realise how fast you are going too.
