Aftermarket fuel pump I'm assuming? If so, the wires on the stock harness aren't big enough or meant to run an aftermarket fuel pump.
You need to add a relay, you simply wire the positive of the relay (constant power) to the battery, hookup the ground, and you use the stock power wire for the fuel pump to tell the relay when to activate and power the fuel pump.
