If it's a GT is has the plug according to the wiring
diagram.
diagram.
paynety2
updates
nope, i have no plug.
Do you have a six fuse block or 3?
paynety2
updates
six fuses
six fuses
Ok /second from the end in the fuse block is a red wire in, it takes a 15Amp fuse. A brown/red wire comes out and goes to the fan relay. The relay will also have a red/white wire , a blue wire and a green/yellow wire. The blue wire goes to the fan motor then to
ground. The green/yellow goes straight to the ecu. The red/white ties into the fuel injection system fuse, diodes, over to the ecu and there connects to two terminals. It also ties into the ignition coils and the fuel injection relay. So it should be easy to find as it's everywhere. You need to ad the relay maybe, I'm not sure. Possible everything from the fuse block on.
ONLY the fan motor is shown as an option in the diagram. The rest of it should be there.
