wisemansyamaha
Just wondering what I am going to need in wheels for the suspension and if I can use the fox float shocks. Apex RTX
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Yes if you use your stock skid you will need to add a few wheels in key locations,and keep the fox floats on,as they are the shocks alot of us run,because of the ease of adjustment,take them down to 30lbs and you will have lowered your front alot,and it was so easy to do too,good luck and make up yourself a good cool down cart,and i believe you can hook into your rear hose that connects between each heat exchanger in the back bumper.
