the kitchen
Plugs will not fix this. You can keep this going if you give it alot of gas after it starts. The reason is that you are getting about 60 to 70% of the available fuel at idle. The TPS will cost about $230.00.
rayone02
- Dec 3, 2010
- adrian, mi
- 2012 Apex 2012 nytro xtx 2006 attak
Here the latest pulled relay switched with no difference. Then drained old gas put new gas with some seafoam cranked over gave a little throttle finally started.
Now the sled starts fine I can not believe some bad gas will cause this type of problem. Going to check tps later. Now the question could it still be the TPS or signs of stator going bad?
CaptCaper
- Jan 1, 2007
- Northern N.H.
- 2016 RS Vector XTX 1.25 Lug .2013 RS Vector LTX. Past Machines 3-2007 Attaks 1-2010 Vector LTX.. 2- 2003 VMax 600ER's.
- New Hampshire
The Kitchen said "Crack the throttle and turn it over and see if it starts. If it starts it will not run on its own at idle. If this runs but not well until rpms are high then it is your TPS "throttle position sensor" It will think that your throttle is wide open and is dumping " Keep this in mind.
rayone02
- Dec 3, 2010
- adrian, mi
Did some testing.
TPS
idle - 16
WOT - 96
Stator
coil resistance - 431
stator - .5
The sled will start now but I think i have a bad stator?
TPS
idle - 16
WOT - 96
Stator
stator - .5
You should have a code 12? Read the other thread. If your CPS (part of the
stator package) is bad the ECM will not let it fire. Shuts down fuel and spark.
It will also throw a code 12.
rayone02
- Dec 3, 2010
- adrian, mi
