superfan75
Hey guys I picked up an Attak suspension for my Warrior today and its in good shape except the sliding frame c part # 8FT-4741-C-00-00 is broke. I've seen that kimpex has a replacement for the c (left side) but not the d (right side). I'd like to change them both since the kimpex is made of steel, but I can't find the right side anywhere. Do you guys know where I could find the right side in a kinpex ? If not I may just change the one that's broken. I know Barn of Parts makes a nice looking brace kit that maybe I will get next year. I spent most of my budget getting the skid and by the time I change some wheels and bushings I wont have much left. Thanx for any advice at all you can give on this skid about maintenance or set up. Thanx
Just have the broken one welded for now until you can afford the BoP ones.
superfan75
Okay I wasn't sure how well they could be welded since there wasn't much metal there. Thanx steiner.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I should have a good used on here to get you by.
superfan75
Actually I talked to the guy I got the skid from and he has one he's going to send me. Thanx Travis. I'm sure I'll need something else from you. LOL.I should have a good used on here to get you by.
They added an extra wheel, a small wheel kit i assume to help with slider wear and that right where that brace broke. Did having this wheel in that location put extra stress on it or.Is this just a common problem with these sleds.
I was also thinking about using my ski doo wheels since they are the size of the oversized wheel kits and taking those small wheels off.
Common problem even without the marginal wheel kit. That's why BoP developed a kit for this.
Also check the rear pivot mount on the rail. They tend to crack there as well. Adding an extra cross shaft will help prevent this from happening.
superfan75
Okay. Thanx again for the advice. I should be able to add an extra cross shaft and I'll take a close look at the rear pivot point to.
- 146K
