kviper
- Nov 7, 2003
- Oakfield WI
- 2012 MCX Turbo Apex
Will a 136 Ice ripper XT hold up in a Turbo Attak and how is every one protecting the rear cooler from stud damage? Will adding some extra to the protector's do it or will the cooler need to be remounted and set up in the tunnel farther? Thanks!
mulot30th
- Jul 7, 2007
- youtube.com
- 2023 thundercat
apex mountain crracing 174
apex blower 136 for asphalt racing
osp drag race sled (apex engine based)
You need to weld-in some tunnel protectors.
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Lakselv - 70N & 25E
- Norway
Been there done that. I relocated the rear heat exchanger up in the tunnel extension (MPI) but it was not enough to keep it out of harms way. I had to add tunnel protectors all the way back over the heat exchanger.
kviper
- Nov 7, 2003
- Oakfield WI
It has the protector's all the way to the rear but will i need to add to them to make them hold the track farther away?
rxrider
Jan-Ove Pedersen
- Apr 25, 2003
- Norway
