bashley
What are all the differences in the Attak and Apex gearing?
The gears, chain, and cover on my '06 Attak are shot and I have to replace. I'm looking on here to find more parts and just want to be sure of what I need to get. Thanks.
MCApex44
- Mar 30, 2006
- Western New York, Chautauqua County
- 2014 Viper RTX SE (sold)
Someone correct me if I am wrong but I believe the Attak has 23/38 gearing and the Apex (ER and GT) have 24/38. The Apex RTX is 22/38 but I think that started on the 2007 model year. Should be the same chain for 23,24/38.
APEX 06
- Apr 30, 2009
- Sheboygan, WI
- www.sheboyganyamaha.com
- 09 Nytro XTX, 08 Apex Mtx
YA the 2006 apex rtx is a 24 top
sherlock29
Yep you are correct....
attack(LTX).... 24/38 with a 70T chain...
RTX....22/38 with a 68T chain....
well this is what is in my two sleds... and they are factory gearing.... somebody speek up if i'm off on this one.... the 23/24 top gear will need the 70T chain.. 22 top the 70T chain does not have enough adjustment on the tentioner... need the 68T.
pedros1983
2006 RTX has 24 top gear stock
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
^^Incorrect^^APEX 06 said:YA the 2006 apex rtx is a 23 top
the 06 RTX ,GT and ER all had 24.
07 RTX 22
attacks have 23
dan
apltx08
ROCKERDAN said:APEX 06 said:YA the 2006 apex rtx is a 23 top
Incorrect.....06 RTX ,GT and ER all had 24.
07 RTX 22
attacks have 23
dan
and LTX have 23Terminator
I believe Rockerdan is correct, I had an 06 attak (23 top), 06 Gt and Er (24 top), and now have an 07 RTX (22 top). I have read that the attak is clutched a little different than shorties to match gearing and track so I would check into it if your thinking of changing from stock gears. My stock attak screamed and I wish I still had it sometimes.
Good Luck.
Good Luck.
apltx08
The Attak/LTX 136" have a WHITE secondary spring wound 3-3 and APEX 121" have a PINK wound 6-1
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
I didn't want to spend the money gearing down so I just added the supercharger to spin the stock 24 gear
APEX 06
- Apr 30, 2009
- Sheboygan, WI
ROCKERDAN said:^^Incorrect^^APEX 06 said:YA the 2006 apex rtx is a 23 top
07 RTX 22
attacks have 23
dan
I had my head in my a-- there. I was ordering a 23 gear just before that post. lol
bashley
Thanks for all the help guys. I'm going to stay stock so I guess I'm looking for 23/38 and 70 tooth chain. With any luck my Y.E.S. warranty will cover it and I won't be looking for anything, just trying to get a head start if they don't.
I liked 23/38 combo in my Apex, except the chain really had to loop around because of the extra slack created by the smaller top gear. I went 40 on the bottom, and put the 24 back on top to correct this. Only thing is, the lower gear for Reverse is around $80 compared to $25 for the top.
btw, good one Kinger!
