redrx1rkt
I am trying to come up with a rough % of error on the dreammeter so those of us without radar or GPS speed can guess how fast we are really going.
So, if you have recorded your speed using radar or GPS and remember what your speedo was reading at the time, please reply. Also, note if you use studs or other mods that may play a factor in your speed readings.
So far my RTX has recorded a high of 119 mph on the dreammeter. That's probably around 107 mph, but would like to figure a % to come closer.
adirondac blue
rx1 are 11%
gillystv
apex spedo
12% off, grind off 1 tooth and it will be 2 to 3 off.
RTX Meirda
119 on the dreameter might be 104MPH
125 is about 108
125 is about 108
youngster66
Speedos
Grinding a tooth off the pick up will get you pretty close to actual speed . My freind and I have tested this out.
waspolarisowner
dreameter 128mph gps 115mph
I thought the dream meter was off by 10% and mentioned this to a couple guys that had been testing with a radar gun on a lake. They dissagreed and thought it was alot closer than that.
87gtNOS
- Nov 30, 2005
- Toronto
- 12 Apex XTX MCX powered
I have one tooth off the pickup, and the most I have seen on my speedo is 116mph.
SledFreak
- Feb 7, 2005
- Ontario. Canada
That's what I thought, it was 10 percent out.fatchance said:I thought the dream meter was off by 10% and mentioned this to a couple guys that had been testing with a radar gun on a lake. They dissagreed and thought it was alot closer than that.
why do you even care? Its just a number, the odometer is actually right on. The speed sensor is acurate, the ecu just fuges the number going to the display. ===SRXSRULE===
87gtNOS
- Nov 30, 2005
- Toronto
SRXSRULE said:why do you even care? Its just a number, the odometer is actually right on. The speed sensor is acurate, the ecu just fuges the number going to the display. ===SRXSRULE===
weird how the speedo cable on the other sleds in the group fudge the number too, eh??
87gtNOS said:SRXSRULE said:why do you even care? Its just a number, the odometer is actually right on. The speed sensor is acurate, the ecu just fuges the number going to the display. ===SRXSRULE===
Didnt know we were talking about old junk with a cable? I thought we were talking about an Apex? ===SRXSRULE===
87gtNOS
- Nov 30, 2005
- Toronto
SRXSRULE said:87gtNOS said:SRXSRULE said:why do you even care? Its just a number, the odometer is actually right on. The speed sensor is acurate, the ecu just fuges the number going to the display. ===SRXSRULE===
We are talking of the Apex, but I ride with some old junk, and their ODO's are ussualy within 2-3 miles of mine.
I highly doubt the Apex dreameter is send different figures to the speedo readout than it does to the ODO.
87gtNOS said:SRXSRULE said:87gtNOS said:SRXSRULE said:why do you even care? Its just a number, the odometer is actually right on. The speed sensor is acurate, the ecu just fuges the number going to the display. ===SRXSRULE===
It sure is. Check it with a GPS, the odometer is bang on. ===SRXSRULE===
- 33K
