Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
- Yamaha nypex mcx 400
Hello. Have a sidewinder 2017 with a idle issuse. Need to give it some throttle to start it and sometimes the rpm fall down to 900-1000 rpm. But sometimes it will idle arround 1300-1400 still low but little better. Have tryed different idle valves, checked every hoose for leak but cant figure it out. No error codes. New sparkplugs, fresh gas. Work fine when driving. Maybe little slow spool up. Does anyone have a tips that can lead me to figure this out?
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Check fuel pressure/ and then maybe new pump
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Take a look at the rubber hose under throttle body that comes off the plastic intake manifold. It supplies air to the idle air control valve.
Mine had developed a kink in the hose and pinched off the air. Also I am running a secondary intercooler so my hose was rerouted.
Exactly the same symptoms as you explained.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Stable on 47 psi on idle, have a secondary walboro pump from front mount catch tank.Check fuel pressure/ and then maybe new pump
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Ok, gonna chech that. Mine is also rerouted, have TD intake and intercooler.Take a look at the rubber hose under throttle body that comes off the plastic intake manifold. It supplies air to the idle air control valve.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Still sounds fuel related to me with symptoms you explained
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Hmm ok. Have 1000cc injectors from td, stock fuel pump that fill up catch tank in front and then a walboro external pump direct on fuel rail with td fuel regulator. Gonna check the fuel system again!Still sounds fuel related to me with symptoms you explained
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hope you find it.. 2 fuel pumps? Not familiar with that set up..Hmm ok. Have 1000cc injectors from td, stock fuel pump that fill up catch tank in front and then a walboro external pump direct on fuel rail with td fuel regulator. Gonna check the fuel system again!
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Yes two pumps. Custom setup to be sure that its deliver enough always.Hope you find it.. 2 fuel pumps? Not familiar with that set up..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Interesting.. Guessing fuel pressure is always very consistent.Yes two pumps. Custom setup to be sure that its deliver enough always.
Fords4life
- Dec 7, 2021
- South Dakota
Check your tps sensor, can check it with on board diagnostics.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
My tps goes from 0.6 v to 3.8 v. And 0.1 to 79 deg.
Yamarace998
- Dec 26, 2018
- Mo i Rana
- Norway
Its idle better when warm. Tested today and its idle at 1400-1450 when 80-90c. But still need to have a little throttle to get it started.
Big_Phil
- Feb 5, 2014
- Wasaga Beach, Ontario
- Sidewinder RTX LE
Has it only idled low since you put the big injectors in? If so, it’s hard to make the sleds idle like a stocker with big injectors. 1000cc is quite large. I ran 430cc on my turbo nytro and it never started and idled as good as a stock sled.Its idle better when warm. Tested today and its idle at 1400-1450 when 80-90c. But still need to have a little throttle to get it started.
