jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I have not measured it, but plenty.. After I loaded it down with bearing mount put a couple hundred miles on, I went to check it and it basically falls right off shaft after removing 3 tunnel/caliper bolts. I will certainly try new concept and report here..How much wear does your shaft have? I will be looking for some people to try out my new concept on a worn shaft.
Fords4life
- Dec 7, 2021
- South Dakota
I believe "shaft only" is discontinued, complete shaft assemblys are avalible, just picked up one a couple weeks ago, lucky i have cat and yammy in same building, big price diff between the two, cat was about 470.00 and yammy otd for me was 332.00....shop around in these times of greed!!Tried bearing mount Green.. No go as the gap was to large. Turned it into powder after some miles. This is a 2021 8000 cat that the shaft was worn @ 180 miles from brand new from factory. I ran the sled for one trip without a wedge and its been garbage since. I looked up a new shaft a few months ago and it was "no longer available" NOT back ordered. ???
EDIT.. I do have a wedge on this sled @ 55lbs torque
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Good to know thanks.. Full assembly meaning the shaft and the drivers correct?I believe "shaft only" is discontinued, complete shaft assemblys are avalible, just picked up one a couple weeks ago, lucky i have cat and yammy in same building, big price diff between the two, cat was about 470.00 and yammy otd for me was 332.00....shop around in these times of greed!!
Fords4life
- Dec 7, 2021
- South Dakota
Yes, drivers and 3 bolt gasket flange included, took mine straight to machine shop for a bearing retaining pin and grove in a new bearing.Good to know thanks.. Full assembly meaning the shaft and the drivers correct?
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
OEM Parts Lookup
Country Cat. Everything Arctic Cat! Large inventory of Arctic Cat and E-Z-GO parts, clothing and accessories in stock. The world's largest Arctic Cat dealer. Snowmobiles, ATV’s, Prowlers, Wildcats and E-Z-GO Golf Carts in stock ready to ride today. We also feature a large selection of Klim, 509...
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Back ordered. Think I will see what BOP comes up with first..OEM Parts Lookup
Country Cat. Everything Arctic Cat! Large inventory of Arctic Cat and E-Z-GO parts, clothing and accessories in stock. The world's largest Arctic Cat dealer. Snowmobiles, ATV’s, Prowlers, Wildcats and E-Z-GO Golf Carts in stock ready to ride today. We also feature a large selection of Klim, 509...www.countrycat.com
rev them up
- Apr 3, 2006
- Prince Edward Island, Canada
- 2011 Nytro XTX, Hurricane Exhaust, K&N, Pcv, Autotune, Pod300, Star Suspension,
2018 Sidewinder, TD Max Spool 17, CAI, TD 3 Inch Stock Muffler Mod, 3Bar, BOV
I got the shaft only Partzilla on April 13.I believe "shaft only" is discontinued, complete shaft assemblys are avalible, just picked up one a couple weeks ago, lucky i have cat and yammy in same building, big price diff between the two, cat was about 470.00 and yammy otd for me was 332.00....shop around in these times of greed!!
rev them up
- Apr 3, 2006
Interested to see what he comes up with. Sled has 8,000 miles on original shaft. Have a new shaft to put on this fall.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Those ordering new shafts.....how do you know you are getting the updated shaft? I don' think there was a new part number for 22 "hardened" shafts. I plan to do a file test with my 22 and see if it appears harder and look for any physical change that one can detect by eye to differentiate.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
rev them up
- Apr 3, 2006
rev them up
- Apr 3, 2006
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
1978,1979,1980 SRX (sold)
I would recommend having anyone testing your new design to sign an NDA so it does not end up with a competitor.How much wear does your shaft have? I will be looking for some people to try out my new concept on a worn shaft.
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
A bit late for that. An NDA only covers the discussion from the point of signing forward to the end of the nda contract. All of the discussion here would not fall under NDA for instance. The fact that it has been discussed here gives any competitor an ability to copy the idea as it is so far with little risk and any modifications that they make would be their IP.I would recommend having anyone testing your new design to sign an NDA so it does not end up with a competitor.
An NDA right now would only cover test results and anything undiscovered at this point in time but the core idea is already out there as it were.
Upstater57
- Apr 25, 2021
- New York
- 2022 Tcat EPS,
2014 ZR9000 (sold)
You are probably correct. A little late for an NDA to do any good. We have some good guys on this forum that work hard to make some of our sleds negative proclivities better. I hate to see them ripped off.A bit late for that. An NDA only covers the discussion from the point of signing forward to the end of the nda contract. All of the discussion here would not fall under NDA for instance. The fact that it has been discussed here gives any competitor an ability to copy the idea as it is so far with little risk and any modifications that they make would be their IP.
