Did some testing with the pressure switch this morning and it works fantastic! The alarm trips around 6-8 seconds upon start up so very fast acting. Did a little demonstration video. I think this is the concept I am going to run with.
I think it is slick as hell, I’ll take three of them.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I am also working on some options to heat the 17-19 roll over valves quicker with electric similar to the new 2020.
You amaze me Travis! Will that cap fit Viper?Did some testing with the pressure switch this morning and it works fantastic! The alarm trips around 6-8 seconds upon start up so very fast acting. Did a little demonstration video. I think this is the concept I am going to run with.
no1b4me
Hi Travis.... you might also want to incorporate a red LED to be mounted on the console as a redundant backup for the reverse beacon, simple LED wiring which could be tied into the reverse beacon wiring from the pressure switch as well ..... just a thought to have both audio and visual warning.
Cheers,
Rob
Sly99
i really like that option.
lilrez
I’m Sold
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
A member on here already sells rollover valves. MTNViper.
https://www.fourstrokesolutions.com/roll-over-valve-kit-features
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Cheers,
Rob
When tying into the reverse beeper circuit for the alarm it does also Display the "R" on the dash so there is some visual indication that something is up as well.
Dr. FeeLGooD
The alarm goes off in the morning and the reverse light comes on when the valve is frozen closed. Nice. What is the best/easiest way to unfreeze it or avoid pressuring up the tank?
I believe it was said if alarm goes off just open up the cap at idle and let sled warm up to defrost itself?
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I like it. Simple is always best.
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
Travis, any update on this?
lilrez
Updates ?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Still working on this. Early snow has really has peaked order volume and I'm not finding much time in shop for R&D. I'm in pursuit of a pressure switch that is self grounded to eliminate the jumper wire that grounds the switch like in my test set up.
Sly99
Stewart Warner Standard Pressure Switches M-364L-F
https://www.summitracing.com/parts/sww-364l-f/overview/
- 125K
