ranger1
In all my years of running sleds I always top up the battery before storage with a 2amp charge, it usually takes about 2 minutes before the green lite comes on because the sleds charging system does a good job keeping it at full charge. Not sure why anyone would want to spend big bucks on these "smart chargers" when you do not need to continuously charge the battery off season. If the battery looses it's charge by snowmobile season it usually means you have something drawing power or it is time for a new battery. Just my 2 cents....which I am saving by not buying a smart charger, lol
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
StreetnSnow said:Does anyone have much experience with using one of desulphatehe CTEK chargers while the battery is still connected? The owners manual suggests disconnecting the battery before using this charger. Not sure if that's to protect the sled's electronics, improve the charging process, or both
I think the concern is that the charger can put out about 20 volts in the desulphate mode which could damage the computer or other electronics
moab11
- Feb 4, 2010
- Thunder Bay, Ontario
- 2016 SKS 155
Bradford said:StreetnSnow said:Does anyone have much experience with using one of desulphatehe CTEK chargers while the battery is still connected? The owners manual suggests disconnecting the battery before using this charger. Not sure if that's to protect the sled's electronics, improve the charging process, or both
I've never had a problem with my ctek chargers on any of my equipment (MUS 3300), mind you if I am running the recondition mode on my MUS 7002, then I have the battery out of the vehicle. IMO the 3300 should never do something to harm the sled, it isn't that powerful of a charger, but is perfect for maintaining and topping off powersports batteries and maintaining automotive batteries too, I have about a dozen of them, everything with a battery has one hooked up when not in use. Haven't dealt with a dead battery in a long time!
Capt.Storm
x2ranger1 said:In all my years of running sleds I always top up the battery before storage with a 2amp charge, it usually takes about 2 minutes before the green lite comes on because the sleds charging system does a good job keeping it at full charge. Not sure why anyone would want to spend big bucks on these "smart chargers" when you do not need to continuously charge the battery off season. If the battery looses it's charge by snowmobile season it usually means you have something drawing power or it is time for a new battery. Just my 2 cents....which I am saving by not buying a smart charger, lol
A agm battery only looses about a percent per month.
Charging can do more harm then good.
icebreaker
- Aug 18, 2010
- Southern wisconsin
- 2011 xtx
What about a 2amp solar charger? you know the cheap $20.00 ones
Capt.Storm
Interesting thought...least it would not charge at night.icebreaker said:What about a 2amp solar charger? you know the cheap $20.00 ones
icebreaker
- Aug 18, 2010
- 2011 xtx
I have been using these now for two years on the xtx through the summer. And the lawnmower , motorcycle through the winter. Guess I will see what happensCapt.Storm said:Interesting thought...least it would not charge at night.icebreaker said:What about a 2amp solar charger? you know the cheap $20.00 ones
vice108
Have been using a battery tender Jr on my 06 apex since 06. I hook it up at the end of the season and it stays hooked up until the season begins again. Still using that original battery now and it still works like new. Every year I'm amazed at how well this battery has lasted
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
Accidentally saw my wife's shopping list. Right there at the top was an optomate 3+. I wonder who that could be for??
Bradford
- Jan 7, 2007
- NB Canada
- 06 RS Nytro
harleyQc
- Mar 9, 2020
- quebec
- Venture rs 2005
My rs venture sleeps outside all winter... i would like to put an intelligent charger. Is there one that can resist the -20 cold canadian winter nights?? I have a Battery tender in my harley but i dont think it could take that coldness.
