grizztracks
TY Advertiser
- Feb 24, 2005
- Scio, NY
Steering effort wasn't bad with the deuce bars. I also placed a 3/16" shim under the rear of the rubber which gets the ski tips up to help reduce darting. What I liked about the stock skis with the deuce bar setup is that it didn't make the steering heavy and handling was predictable in most conditions. I tried other dual carbide skis and hatted how they pushed in loose conditions and most of all how unpredictable they were with changing conditions.
nytroman21
- Oct 28, 2014
- Pecatonica, IL
- 08 nytro
Sweet, I will definitely try that setup out. Sounds like a cheap easy fix which is exactly what I was looking for. Thanks man I appreciate it!Steering effort wasn't bad with the deuce bars. I also placed a 3/16" shim under the rear of the rubber which gets the ski tips up to help reduce darting. What I liked about the stock skis with the deuce bar setup is that it didn't make the steering heavy and handling was predictable in most conditions. I tried other dual carbide skis and hatted how they pushed in loose conditions and most of all how unpredictable they were with changing conditions.
nytroman21
- Oct 28, 2014
- Pecatonica, IL
- 08 nytro
Can anyone tell me if this battery will be a direct swap with my OEM one? This brand was highly recommend to me several times on another fourm.
http://store.yuasabatteries.com/p/ytx20hl
nytroman21
- Oct 28, 2014
- Pecatonica, IL
- 08 nytro
Never mind on the battery yamaha parts house is the way to go!
