Vmax4creed
Supercharged Apex bored injectors to 525, Secondary fuel pump, PCV with autotune, Ignition module. At 10% throttle this thing is loading up to 10AFR i see its going from 8 on the block before up to 19/20 in the 10% 7700 rpm block. I dont know why its adding double from the previous rpm & throttle block & why is the Autotune is allowing this to happen when the richest i am in the table is 11.8 @ WOT. When i reduce the fuel slowly in the block goes super lean 14.8. Anyone have a battle like this battling a couple of odd ball blocks in the fuel map?
kinger
I had a similar problem with the MPI GEMS module it would run really lean at a certain RPM and it was a hole, I made it richer it went way to rich and bogged, then back to way to lean. I chalked it up to the limitations of the resolution of the controller.
Vmax4creed
Kinger were you eventually able to get rid of it ?? thought this would be a piece of cake with the power commander tune ability compared to the gems it is proving otherwiseI had a similar problem with the MPI GEMS module it would run really lean at a certain RPM and it was a hole, I made it richer it went way to rich and bogged, then back to way to lean. I chalked it up to the limitations of the resolution of the controller.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
Unhook your OEM MAP sensor (between cylinders 3 & 4 on the throttle bodies), it will throw a code, but ignore it & see if that makes it work as it should. I believe what you're running into is the OEM Map sensor getting confused as it sees from vacuum to boost transition.
Vmax4creed
Thanks Alan I will give that a try.
Vmax4creed
Turned Auto tune off & focused on those sells on the fuel table ended up taking quite a bit out to get afr decent seems good now , will be running auto tune again now to fine tune it.
kinger
So what fixed it exactly?
kennyspec
I believe the PCV will only allow the autotune to adjust trims between 11.5 and 14afr. If your at 10.0 it wont adjust fuel.
ateick
- Mar 11, 2019
- '24 Rene XRS 900R
'18 SR Viper RTX (SOLD)
'20 Poo XCR 850 (SOLD)
I'm not sure on the lean side but on the rich side PCV will not allow autotune to adjust trims below 11.0. When I was tuning my Viper with Hurricane turbo I kept trying to get to 10.5 and it wouldn't. Contacted Dynojet and had to download a patch to allow below 11.0I believe the PCV will only allow the autotune to adjust trims between 11.5 and 14afr. If your at 10.0 it wont adjust fuel.
Vmax4creed
Took quite a bit of fuel out of the cells @ 10% throttle range finally AFRs came around. I didn't realize the autotune couldn't adjust as rich as 10 AFR will be logging miles now with it on to hopefully be able to accept trims & dial it in .So what fixed it exactly?
farmerz24
- Nov 3, 2006
Did you leave the stock map sensor connected ? Surely it must be required to provide proper fueling in vaccum up to 0 vac?
Vmax4creed
It still has the stock map sensor, I got it close the end of the winter but still not great. I will get it this winter for sureDid you leave the stock map sensor connected ? Surely it must be required to provide proper fueling in vaccum up to 0 vac?
