WootTootViper
- Jan 7, 2018
- Illinois
- 2014 Viper MPI turbo, taller gearing, Ulmer clutch and tuning.
I talked to a shop about replacing my jackshaft bearings. He said if I can change my own chain case oil I can change my own jack shaft bearings. Any tips and tricks and what bearings to buy? Any information in general is a blessing thanks guys!
slowride06er
WootTootViper
- Jan 7, 2018
- Illinois
Thanks I was looking for this and couldn’t find it
slowride06er
You're welcome.
Was this helpful?
Was this helpful?
WootTootViper
- Jan 7, 2018
- Illinois
It started the rabbit hole so I’m sure it will lead to everything I need thanks
rbell14
Couple slick videos...
Give this one a few seconds of play as it will become snowmobile video.
WootTootViper
- Jan 7, 2018
- Illinois
Is there a kit I can buy that contains all bearing and seals and whatever else is needed??
No. You could buy entire inner case which has them in already but they are pretty easy to replace with case in sled. Heat the case and freeze the bearings they slide right in.Is there a kit I can buy that contains all bearing and seals and whatever else is needed??
