jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Anyone replace these yet? Anyone have a lead on better bearings besides OEM? Thinking about replacing them soon. If not this preseason by the end of year. Either bearing pressed on? Pretty sure the top is not but not sure about bottom. I realize these should be good for 10k? But wondering if anyone had any thoughts or have done them?
thanks. Jon
thanks. Jon
Sly99
the bottom its pressed in. heat the chain case around the bearing with a heat gun. there also a seal at the back of it. heat it also with a heat gun, easier to remove. put the new bearing in the freezer before to install.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks brother. The bottom should last a long time. It’s riding in lube alotthe bottom its pressed in. heat the chain case around the bearing with a heat gun. there also a seal at the back of it. heat it also with a heat gun, easier to remove. put the new bearing in the freezer before to install.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Does anyone know if the assembly/ drive shaft with drivers come with a new bearing on that shaft? I had the shaft and drive bearing on brake side replaced but I’m wondering about the drive shaft bearing on chain case side?
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Mine didn't.Does anyone know if the assembly/ drive shaft with drivers come with a new bearing on that shaft? I had the shaft and drive bearing on brake side replaced but I’m wondering about the drive shaft bearing on chain case side?
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Just did mine. Replaced them with FAG brand bearings. I removed the whole inner case and just pushed them out with a seal driver. Good time to do the left side bearing also. That bearing is Yamaha only.
DMCTurbo
- Nov 12, 2005
What do you mean by "that bearing is yamaha only?"Just did mine. Replaced them with FAG brand bearings. I removed the whole inner case and just pushed them out with a seal driver. Good time to do the left side bearing also. That bearing is Yamaha only.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
It is a 6206 bearing like the chain case side BUT it has a different inner race to fit the upper shaft. The only source I found for that bearing is Yamaha.
Check this thread https://ty4stroke.com/threads/bearing-question.158166/#post-1498113
Turboflash
- Mar 18, 2019
- Southern MN
Both run in an oil bath so unless there was some other reason, I doubt they need replacing. They should last a very long time.Anyone replace these yet? Anyone have a lead on better bearings besides OEM? Thinking about replacing them soon. If not this preseason by the end of year. Either bearing pressed on? Pretty sure the top is not but not sure about bottom. I realize these should be good for 10k? But wondering if anyone had any thoughts or have done them?
thanks. Jon
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I was changing my track anyway so I decided to do it all while I was in there
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Hey John,Does anyone know if the assembly/ drive shaft with drivers come with a new bearing on that shaft? I had the shaft and drive bearing on brake side replaced but I’m wondering about the drive shaft bearing on chain case side?
Good to see your back! You must have been catching a lot of fish this past open water season! Missed you!
If you need those drivers pressed on I can do them for ya. just remember if you do them they are indexed onto the shaft, so keep them both the same.
PS big snow up by your cabin yesterday and today!
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
What track did you go with BTW?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Hey bud thanks. Great fishing this fall. Actually guided a little for musky. Not my species of choice but when someone has a bucket list I was happy to boat a nice 42”. I went with the same track that came on sled. Rip saw2. I know your going to rip me for that, but I liked that track with my stud pattern. She hooked out of the hole quite nicely. Going just slightly longer on studs. 1.425 gold diggers. I’m thinking I will just replace both the chaincase and jack shaft secondary side after this year. The dealer said the 2 inside looked really good. Thanks for the offer and I will take you up on that after this season. I will shoot you some dates when I will be UP. YOUR welcome to come up again.What track did you go with BTW?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
The new shaft comes with new drivers on it already. But I could use your help on those bearings that are pressed on.
Turboflash
- Mar 18, 2019
- Southern MN
Bearings are not pressed on. That's the whole problem. Both sides, the shaft just slips inside bearings. UNLESS, one does something to change all that.The new shaft comes with new drivers on it already. But I could use your help on those bearings that are pressed on.
