scottt
- Jan 30, 2018
- maine
- 2007 apex gt 2017 sidewinder LTX LE 137"
I recently had my 17 sidewinder at the shop for a go over. I told them the belt would sometimes squeal when you stopped. They found the primary spring broke and said everything was good,they installed my new spare belt.. Well I fired it up on the trailer the other day and the squealing is worse then before. Belt still seems tight,,,runs about a good 1/16th" above the secondary. Probably will have to run flush. I was thinking about just installing one of those belt adjusters. Looked at BOP and thunder products. A good idea and what would be your preference? THanks
![](/styles/TYLifeMember.gif)
![](/styles/vip.gif)
DennyTuna
- Jan 28, 2017
- Ohio
- 18 Winder LTX 50th
16 SR Viper RTX (red)
02 SX Viper ER (red)
97 SX Vmax 600 (red)
Any of the adjusters work well, with that said I use Thunders. With a stock 8JP belt you should be 1-2mm below top of sheave.
Remove a shim from the clutch bolt.
scottt
- Jan 30, 2018
- maine
Yes but I thought the belt adjuster would make for a quick change and would be nice to really dial it in. No?Remove a shim from the clutch bolt.
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Thunder’s adjuster works great.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I love my Thunder Products belt adjuster!
Yes, you are absolutely right. Im not a fan, as I like to keep things simple, but they work.
Trussman
JAFO
- Mar 18, 2007
- WI
- 2004 Viper S
2017 'Winder
2022 SRX
..........another vote for Thunder's
scottt
- Jan 30, 2018
- maine
Ordered one last night. Seems simple enough to install after watching YouTube video.
Shims come in all sizes.....Pretty simple
scottt
- Jan 30, 2018
- maine
Well I installed TP belt adjuster...can't get the belt to sit flush..still. a good 1/16" above the secondary, still squeals. Ran it on a stand. With engine off I can move secondary clutch in and out a 1/16" so there's no pressure on the adjustment wheel.
scottt
- Jan 30, 2018
- maine
Forget that,,,had a numb spell
DennyTuna
- Jan 28, 2017
- Ohio
Did you remove the factory screws on the backside off the clutch? So, to get the belt lower in the sheeves tighten the adjuster to open the sheeves more.Well I installed TP belt adjuster...can't get the belt to sit flush..still. a good 1/16" above the secondary, still squeals. Ran it on a stand. With engine off I can move secondary clutch in and out a 1/16" so there's no pressure on the adjustment wheel.
scottt
- Jan 30, 2018
- maine
Yeah I feel stupid for posting that before thinking. I got in the house and then realized I had yo screw it in the widen the clutch. All it took to not creep and stop squealing was drop the belt down maybe a 1/16". It's still just a hair above..maybe 1/32". We're going riding tomorrow so I'll see how it goes. Still kinda weird with the new primary spring it's engaging at 3500 rpm. I'll have my primary weights with me.
