hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Belt adjusters for Sidewinder and Viper have been on the market for few seasons now, but those designs are specific to just those two sleds and will not work on any of the Japan build sleds.
I've got an adjuster design that will work on almost all of the Japan built sleds except for the phazer. As machined it will fit the Viper and Sidewinder. If I drill out the M10 through hole to an M14 it will then fit the Apex/Vector/Venture sleds. If I drill it out to an M18 it will then work on the FX Nytro. With one design for machining, it will allow me to keep my costs down.
Here's a photo of it installed on my Sidewinder. More details to follow.
guardrail
I'd buy one.
Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Nice idea, Travis! How does the adjustment work, and can it be used to push the sheaves open for easy belt change?
Approximate price you have in mind?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes, it can be used for easy belt changes too. Still finalizing the whole set up. Once I have them done I'll post up a little video showing install and how it works.
Targeting a sell price in line with current ones on the market for sidewinder and vipers which are $90.
The center section, which I will call the core will be the only variable between different models. My plan is to offer cores too, so if down the road you want to swap the adjuster to a new sled you will only have to buy the core and not the whole adjuster.
dennyboy
- Oct 4, 2013
- Minnesota
- 2012 nytro XTX 1998 srx 600
what are they used for exactly? ive seen acouple different kinds for sale but don't know what it does.
YukonMP
- Dec 25, 2014
- Yukon Territory
I'm with you dennyboy. Also, will it work on the Venture Multi-Purpose. I only ask because it is the 'forgotten' Venture with the same engine as the Phazer.
I like how the action is picking up on the site, we have snow on the ground today.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
The belt adjusters make setting belt deflection simple. If you'd ever had a sled squeal when sitting still the belt deflection is incorrect. A squeal means the belt is too tight. To adjust, the secondary would have to be removed and then washers removed from the 3 adjustment screws on backside. Taking washers out opens the secondary clutch and relieves a tight belt. The belt adjusters essentially open and close secondary clutch on the fly for quick adjustment. Correct deflection improves performance and belt life.
Since the adjusters can open the clutch they also allow for easy belt changes.
dennyboy
- Oct 4, 2013
- Minnesota
Awesome ill have to get one. No squeal but at 12k in sure she coukd be adjusted. I assume you leave it on once you get it set right?
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Yes it stays in place all the time.
Belts strech and get narrower over use and results in loose belt. A loose belt can result in an abrupt engagement and also results in the sled pulling out in a taller gear as belt contact will be higher on primary and lower in secondary.
It can be adjusted via oem provisions, just not as convenient. if you want to learn more about the oem method I will gladly assist.
dennyboy
- Oct 4, 2013
- Minnesota
when there ready i will order one doing it the oem was looks terrible haha
Snorover
- Apr 15, 2003
- Kittery/Fayette,Maine
- 2017 Viper
Nice idea, I'll be waiting your post on the directions.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Made up a quick video this morning to explain how my adjuster works.
cnybrian
- Oct 6, 2011
- Cato, NY
- 2006 Yamaha Attak
- Cato, NY
I'd be in for one for an Apex/Attak
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
Waiting on shim tools and some hardware, and then I should be able to start shipping orders out by end of week. I've added them to the website and they are also in the online store for purchase.
http://www.barnofparts.com/belt-adjust-change-tool-new
yank
- Jan 3, 2006
- Cook,MN
- 2005 rs venture
2006 rs rage
1971 elan
I'm very intrigued by this. Especially since the 3 shim bolts on my venture keep wearing their way into the sheave so you eventually run out of washers to remove and have to get longer bolts. My question is, does the new adjuster allow for the small amount of side play of the secondary on the jackshaft, which I believe helps with belt alignment? I couldn't tell from the video.
