theewarrior
What's people use to clean brake dust of panels,and under hood air intake
- Apr 14, 2003
- Hessel, Michigan
Starting fluid works good in the clutch area (if it doesn't wipe out with just a rag)
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Brake cleaner for brake dust, make sure you read the can.
DranttelSS
TY Advertiser
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
Simple green and water with a soft scrub brush.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
This is what I use with very good results.Simple green and water with a soft scrub brush.
rbell14
Tried Sled bright and it worked awesome. Removed all the belt dust nicely and even removes the discoloration from the exhaust on the plastic panel.
Is it the plastic version? Can you post a picture of the bottle?
rbell14
Bio-Kleen S07107 Belly Pan Cleaner, 32 oz.
https://www.walmart.com/ip/SLEDBRITE-BELLY-PAN-CLEANER-32-OZ/158997614
Cheaper on Amazon I think.
- Clean Black Exhaust Stain from Snowmobile and Snowmobile Parts
- Safe on Sled Decals and Plastic
- Clean Snowmobile Belly Pan, Belts, Clutches and Equipment
- Biodegradable, Non-Toxic
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
Simple Green for approx 1 minute then quick rinse, never experienced plastic fade or decal damage.
XP123
- Dec 25, 2016
- Chautauqua NY
I just bought this on ebay and have yet to try it.https://www.ebay.com/itm/Bio-Kleen-...e=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2649Bio-Kleen S07107 Belly Pan Cleaner, 32 oz.
WinterWolf
- Mar 25, 2017
- Connecticut
SD 20 degrease..works great for belt/brake dust stains on my white side panels of my 50th anniversary Winder. Spray on and wipe off..that’s it!
I had a very small/tiny exhaust stain right at the bottom of the panel by the muffler outlet, and it took that off too. I like it.
