rtx moose
- Jul 31, 2014
- WATERTOWN,MN
so what would happen if i broke down on the trail with only an 8dn for a spare on my sidewinder..will it run bad or does it even fit?
WinterWolf
- Mar 25, 2017
- Connecticut
It’ll be fine. You can use That belt. It’s just a tad longer than 8JP.
Byam
You will only need 1 washer behind the secondary bolt for 8DN lengthso what would happen if i broke down on the trail with only an 8dn for a spare on my sidewinder..will it run bad or does it even fit?
the 8 dn will get you home. top speed will not be as high but getting home is usually good enough.
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Best spare you could use. Cheap price and HARD TO BREAK. Have to adjust for longer length. You will loose 2-4 maybe. Won’t matter when you run your doo guys.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
It will be easier to install & you'll hardly notice the performance difference.
It's actually my back-up spare
- 10K
