Rynomite18
After doing some research, I can definitely tell my subframe is tweaked. Shocks are not centered between a-arms and ski stance is off. Used the pry bar method to straighten and got shocks (mostly) centered but haven’t added gussets, so lasted about one ride and tweaked again... The part I can’t figure out is the angle of the spindles being so far off and different.. see pics. Any advice on correcting is appreciated! Thx!
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
If you get the shock to center between the upper arm then both of your spindles should be at or really close the same angle. Really the only way to fix this is to put the gusset braces in other wise it will just keep going right back to where it is now.
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
You probably ride hard and fast, as deeppow16 mentioned if the shock is centered everything else will fall into place. What I found through trail and error on my XTX was the weak shock valving and wimpy front shock springs were to blame for my bent subframe. What happens is the stock shocks bottom out VERY easily, once the shock bottoms the frame then has to take the loads which in turn bends the subframe. I straightened my subframe using the prybar technique, bought a set of used aftermarket Fox Shox that now can take the loads and have never had another issue, never reinforced or replaced the subframe.
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
Like the last 2 mentioned, I'd guess that once the shocks are centered the spindles will match up. Looks like one shock is towards the front and the other is towards the back...
I went through this on my Nytro a while back. I straightened things out using the pry bar method and then gusseted the sub frame. Haven't had enough snow in Western WI to really test it out much yet....
Grimm
Double check the A arm and ski spindle bushings as they could be worn as well. Raise the sled off the ground so the ski hang loose. Then grab a ski and push/pull to see how worn they might be. They should be tight and not rattle much
Gone Blue
- Oct 11, 2006
- Howell, Michigan
Ball joints too! G.B.Double check the A arm and ski spindle bushings as they could be worn as well. Raise the sled off the ground so the ski hang loose. Then grab a ski and push/pull to see how worn they might be. They should be tight and not rattle much
yamahinn03
- Dec 28, 2004
- oshkosh, wi
- 12 Nytro XTX (mine)
06 Apex GT (wifes)
07 Phazer (#2 sons)
02 Viper (#1 Sons)
I have B.J. that is gonna need some attention in the spring. What has everyone been using?
Rynomite18
Thanks for all the feedback.. I was able to pry it back to “almost” straight.. spindles are still off, but better.. definitely a lot of play in the skis.. next will be to add the gussets. Does the subframe need to be removed to add them?
After that is bushings and ball joints.. any suggestions on where to source everything is appreciated!
m.schuey7
- Feb 4, 2014
Bought my longer front shocks from Carver Performance. You can also check Ebay or the classifieds on this site.
- 11K
