IH8CROWS
I've been chasing a vibration for months and visually it looks like the jackshaft is bent.
I've done everything you can think of to eliminate to get it down to this.
I'll get a dial indicator tomorrow.
Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
Which sled is this on?have you ever changed anything on the driveshaft?I'm dealing with the same thing but only hear& feel it when braking/slowing down.mine has been narrowed down to adding 2 extra drivers as It did not do it before with just 2 original driversI've been chasing a vibration for months and visually it looks like the jackshaft is bent.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Make sure the J-shaft bearings are in good shape. If it’s gradually getting worse that’s probably the issue.
IH8CROWS
2008 Anniversary apex.
All bearings are brand new in the chaincase and jackshaft and driveshaft.
I was chasing it in the tunnel and skid forever.
Today i took track and skid out and put case back together.
Still vibrates about 65 mph and above.
I also had a new drive shaft and drivers in it and still vibrated.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea sounds like you better indicate the sob.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Check your brake rotor too
IH8CROWS
At the moment rotor is off and still vibrates but will check that also with gauge tomorrow.
New jackshaft is crazy$$ 219.61 from Partzilla. Damn
Yamajon1
- Nov 6, 2016
- Oshkosh Wisconsin
- 2016 SR Viper RTX DX
Former Yamaha sleds:
2004 Venture 600 2002 SX Viper 700
1997 Vmax 600 SX 1994 Vmax 600 1989 Exciter
1986 Vmax 540 1986 Phaser 1981 SRX 440
Check with Barn of Parts
RobX-1
- Coldwater, OH
Most definitely. When it comes these older, but well maintained, machines, Travis is the first person I contact for used parts and everything I have gotten from him have been in really good shape so I will 2nd Yamajon.Check with Barn of Parts
IH8CROWS
So I used a gauge today.
Hard because everything is aluminum and the magnet holder stand don't stick.
On brake side i only got .0005 difference.
On clutch side the best i could get was .002 difference.
So is that enough to give me my vibration?? Or not even close.
Thanks....
Thanks....
IH8CROWS
I asked barn of parts and they do have some to fit mine.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yeah not even close,that's not your problem if you measured right that's as close as it would ever be.you can get a used shaft for about $60 but I don't foresee any better result by changing it.did this just start out of the blue or after you changed something etcSo I used a gauge today.
Thanks....
IH8CROWS
That's the other thing. I got the sled last summer and right away started tearing it apart and replacing stuff just because I like projects. So I don't know if it already did it before hand.
I guess I will take the chain out of the case and then run it.
That will eliminate the bottom half of the case and bearings ...etc.
Then it would only leave the secondary and top half bearings or jackshaft thats doing it.
I already replaced the back half of the secondary sheave because that appeared warped.
There is brand new bushings in the secondary and helix and also new helix ramp shoes.
All the bearings in the case and clutch side are new.
I had a brand new axle and drivers in it also and it vibrated.
There's also a brand new belt on it. So that aint it.
Going to call a friend and see if I can borrow his secondary for an hour.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
I have seen warped brake rotor cause a lot of vibration so try leaving it off also
