Brotherdan
- Sep 8, 2017
- Belmont,maine
- 2011 apex xtx blue, starr suspension,gytr front shocks,camso 1.5 track cut down, snowtrackers work in process,2003 rx1er originally 121 converted to 136"monoshock 2 ck136 rear suspension with clicker vector ltx shock,muffin works tunnel extension, seat concepts(wrp) seat,apex hooked handlebars converted to all underhood wiring,8"lake effect billet aluminum riser,gytr frontshocks,yamaheater hand warmer kit,rocks ridelite,rocks power supply, rocks heated bag,, tunnel braces,blue skid plate,garmin gps, aggressive snowtrackers on apex single keel skis,rollerski ski wheel kit,108 warthog studs&blue studboy backers,pioneer wheel lowering kit, dupont slides, 4th wheel kit,yamaha saddle, tank& windshield bags, powermadd led handguards, bar mount mirror kit, apex radiator& electric fan added, apex rear cooler,autometer temp guage, apex new style large diameter drive shaft with extroverts machined for chaincase,thunder products clutching,1987 enticer 340ltr 2100miles,1984 enticer 340,1996 wolverine 350,big wheel kit,winch,racks,k&n,full skidplates
With secondary removed&chain removed how does the jackshaft feel when turning.also did you have the whole jackshaft out?also try a different belt even though you have a new one on there,clutch alignment is correct? assume you don't have vibration with belt off?Took chain out of case and still vibrates.
Rotor is off also.
Get buddies secondary tomorrow and if still vibrates after trying his then only thing left is the jackshaft.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Absolutely could be fluted bearings!
IH8CROWS
With belt off and chain off I spun
The secondary using a drill and socket on the secondary bolt. I still feel the vibration.
I did have the whole jackshaft out when i started the project and was putting new bearings everywhere.
What do you mean by fluted bearings?
Brotherdan
- Sep 8, 2017
- Belmont,maine
Well there's your problem then.jackshaft has bad bearings or possibly a spacer installed wrong etc.has to come apart&check all pieces for proper direction& then check each bearing.what clutch master means is the race of the new bearing is defective/grooved causing the vibrationWith belt off and chain off I spun
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Did you check the secondary clutch for runout?
That’s about all I can come up with.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
You should probably be able to see it with the naked eye if it’s that bad
Brotherdan
- Sep 8, 2017
- Belmont,maine
I would remove the secondary clutch&spin the shaft with your drill again to take the secondary out of the equationWith belt off and chain off I spun
IH8CROWS
Tried that, but hard to tell because the bolt isn't trueI would remove the secondary clutch&spin the shaft with your drill again to take the secondary out of the equation
I'm frustrated now.
Just gonna get a jackshaft from barn of parts and go from there.
Brotherdan
- Sep 8, 2017
- Belmont,maine
When you had the jackshaft apart there is a bearing collar nut (that can go on two different ways)did you verify it is installed correctly?it's been discussed&caused many problems in the past.according to your dial indicator measurements I don't believe your shaft is bent,when you just turn it by hand with everything else taken off does it seem rough?it should turn very smoothTried that, but hard to tell because the bolt isn't true
I'm frustrated now.
IH8CROWS
I was confused and made a post long ago asking about that nut.
It's goes on this way easily and hard as hell if you flip it.
https://ty4stroke.com/threads/jackshaft-spanner-nut-which-way-does-it-go-on.157349/
Brotherdan
- Sep 8, 2017
- Belmont,maine
Yes the parts fische is incorrect,you have it facing the correct way.are these yamaha bearings?how hard did it come apart originally?I would pull a seal&clean out the bearings&make sure all of the balls&races look good.its rare but not impossible to have a bad bearing.its also possible the shaft is bent but seems the dial indicator would have picked that up.View attachment 149238 Turns nice and smooth, but when spun fast you can feel the vibration. New bearings both sides.
