LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
Who has the best aftermarket fix for this - or what can I get the dealer to do to eliminate this altogether. My primary spring is chewed on the outer edges.
Keeping sled stock.
Keeping sled stock.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
- 2017 Sidewinder BTX LE
2012 Nytro XTX 1.75
It doesn't seem to matter what spring is in the primary it will chew up the sides I have tried TP orange TP black and yam white white white and they all have the paint wore off the sides with just a few miles on themWho has the best aftermarket fix for this - or what can I get the dealer to do to eliminate this altogether. My primary spring is chewed on the outer edges.
Keeping sled stock.
WinterWolf
- Mar 25, 2017
- Connecticut
I want to keep my 18 stock too...so this is something that has to be lived with..no fixes?? Does this happen to every single Sidewinder??? I've seen many guys on here with 2017 Winders that have thousands of miles on, and haven't had any belt or clutch problems; are there Springs being chewed too?? If so, it doesn't seem to be causing that much of a problem for those who have thousands of miles and no issues with clutch/belts.
LouTurbo
- Dec 19, 2016
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
I only have 1200 miles on mine, blown 2 belts. Changed out flat rollers once after first belt, then 2nd belt blew 500 miles later. Im going to try the Cat rollers and throw in a new spring, unless there is a better option.
I dont race, just lake and trail riding.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Get the glide washers and a shorter spring.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Not sure what the glide washers do........springs don't turn as they are compressed
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
Ride it stock I got good belt life out of mine and the primary springs wore the paint off the side it's just the nature of the beast. If you have belt issues then look into a different sec spring, rollers and helix so all your rollers touch and won't bind I don't believe the primary has much to do with the issues if you plan on keeping it stock ride it and see the sec rollers aren't a bad idea right away.I want to keep my 18 stock too...so this is something that has to be lived with..no fixes?? Does this happen to every single Sidewinder??? I've seen many guys on here with 2017 Winders that have thousands of miles on, and haven't had any belt or clutch problems; are there Springs being chewed too?? If so, it doesn't seem to be causing that much of a problem for those who have thousands of miles and no issues with clutch/belts.
WinterWolf
- Mar 25, 2017
- Connecticut
Sounds good Dieselxtx. I just ordered the Heavy Duty Rollers from Turbo Dynamics and will put those in at set up(not even going to take a chance with the stock rollers since they haven't been updated it seems).
Thanks for the response!
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I put cat rollers in early last year, all three contact my dalton helix nicely, never had a single belt issue in 2000 miles, changed belts mid season just because... 900 miles on TD power trail.
LouTurbo
- Dec 19, 2016
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
Dan and all, Who supplies the glide washers and what is the material?...I forgot all this over the summer.
LouTurbo
- Dec 19, 2016
Pilot Skiis
STOLEN Nov.14, 2022
- Woodbridge, ON
Searched it - Thunder Products, getting rid of this laziness in time for winter.
In the winter the strong go north.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Incorrect.Not sure what the glide washers do........springs don't turn as they are compressed
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
I run glide washers on my winder but I'm not sure they are required if the spring turns in the primary the spring would have all the paint rubbed off the top and bottom I haven't seen that happen on any of the sleds I own? I'm open to where there is proof to this spring moving enough to matter I'm not convinced? I'm not saying it doesn't I'm just looking for proof to close this debate?Incorrect.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I stand corrected. I ran some primary springs through my spring compressor/tester and found they do twist/deflect slightly.Incorrect.
Dieselxtx
- Feb 21, 2016
- Fox Lake, WI
2012 Nytro XTX 1.75
That is exactly what I was looking for I guess I will run glide washers in all my sleds from now onI stand corrected. I ran some primary springs through my spring compressor/tester and found they do twist/deflect slightly.
