psykes87
- Feb 16, 2023
- montréal
- Yamaha apex ER 121 2007
Hello, apologies if this has been discussed
My apex 2007 er with 8xxx km has a small exhaust leak. I heard about the gaskets made of cooper but some warn against them because the eat up the pipes. Is this true? Where can I get the best quality one (ideally in canada) but willing to order from the USA if needed.
Heard yamaha updated the donuts, what is the part of number of those? Should I also change the clips? How long those new revised one last?
I ideally wanna do this job once
thanks!!
thanks!!
basic700
- Mar 5, 2010
- Norwalk WI
- 2018 Sidewinder STX DX 146
2015 SRViper XTX LE
2009 Nytro XTX
FX Garage Works they are out of canada and eliminate them dang donuts!
Copper donuts with the SS y-pipes have lasted 15,000 miles on my sled without leaking or breaking a pipe
If your sled still has the original titanium header pipes, I would recommend changing to the newer steel pipes.Hello, apologies if this has been discussed
thanks!!
Adding a homemade hanger at the muffler y-pipe connection also helps the pipe not to crack
TrueBlue
In what year did they install the new steel pipes. I have a 2018 Vector & the pipes broke at the y-pipe.If your sled still has the original titanium header pipes, I would recommend changing to the newer steel pipes.
TrueBlue
Pictures would be great.Adding a homemade hanger at the muffler y-pipe connection also helps the pipe not to crack
Fast Lane
- Feb 6, 2020
- Winnipeg
- 2007 Yamaha Nytro ER
- Winnipeg
I would just replace the donuts with the Yamaha ones. Its not that big of a deal. I changed mine for the first time this summer.
The Vectors were always steel.In what year did they install the new steel pipes. I have a 2018 Vector & the pipes broke at the y-pipe.
I can't remember for sure what year the Apex switched back to steel, but the 06 and 07 Apex were titanium for sure from the factory.
Bob Miller
- Apr 19, 2003
- New Milford CT
- Present Sled: 2011 Yamaha Apex 128
I have worked on and repaired exhaust systems on several Warrior's and Apex's, including 2006,2007, 2008 Apex's and Attak's. I owned an 04 Warrior and I presently have a 2011 Apex. I'm a Welder/ Mechanic by trade. I have replaced the Exhaust donuts on many of these Yamaha's and I use The Copper Donuts! I have welded cracked and and damaged exhaust on many occasions and I know what type of material they are made of. 2003 -2010 are Stainless Steel, 2011-2018 with EXUP are Titanium. I have not worked on any Vector's but they are probably Stainless Steel?
03-04 RX-1's were steel head pipes.
05 RX-1 titanium.
06-09 Apex titanium.
2010 Apex steel.
2011 and up titanium(EXUP style).
05 RX-1 titanium.
2010 Apex steel.
Stubbs
- Nov 7, 2006
- Uxbridge, On, Can.
+ other gooodies
- Uxbridge ON
This is what I’ve seen over the years as well.
pdiddy
- Oct 12, 2004
- Southern Maine
- '11 Apex; '16 Apex XTX; '18 Indy 600 SP;
Why did they use titanium to save ounces when the only thing anyone cares about on the Apex is the engine?
Bob Miller
- Apr 19, 2003
- New Milford CT
I owned and repaired my 04 Warrior's Exhaust by welding a break at the crossover, and I am a Certified welder! They are Stainless Steel! I've also welded 2006-2008 Apex exhaust for customers and they are Stainless Steel! I presently own a 2011 Apex with EXUP and that is when they started using Titanium! https://www.amazon.com/Yamaha-Stainless-Exhaust-Y-Pipes-2006-10/dp/B010GESSQC
Bob Miller
- Apr 19, 2003
- New Milford CT
Picture of 2011 Titanium Exhaust Being Heli-Arc welded
