hunterrayhorvath
- Feb 8, 2023
- Ann Arbor
- 2021 Yamaha Sidewinder LTX-LE
Hello,
I was wondering what the best ski ice scratchers are. I have CA Pro Skis and I would like to install them without drilling any holes.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
BOP scratchers for skis. Still good and working well after 4-5 seasons! Only prob is coming up with away to secure them during non use! Wire works best!
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I bought a set of ski scratchers and they came with a mount for when not in use....hold please.BOP scratchers for skis. Still good and working well after 4-5 seasons! Only prob is coming up with away to secure them during non use! Wire works best!
Doc Harley
- Oct 17, 2016
- Here & there
They don't show amount but it definitely has them. Maybe you can contact them and see if they're available separate
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
I use the yamaha rail mounted with great success. Have for years they are reasonably priced easy to mount. Only down side to them they don’t like reverse very much. They only bend back a few times and then they break off
They are easy to mount is why I like them and very effective in cooling.
You can find them in the Yamaha online website
turbogts22
- Jan 16, 2021
- Spooner, Wisconsin
- Two 2010 Phazer GT's
I had a set of aftermarket Ski Doo rail mount scratchers that wouldn't fit on the rails due to wheel placement. I fabbed up some aluminum brackets to mount them to the wear bar studs on a set of Curve skis. Also used a piece of heaven stainless wire to hold them in the stored position.
No holes drilled and works great.
- 8K
