Mcmarkrazz
- Dec 28, 2013
just looking to upgrade my ski from my stock set up on my 2013 nytro
I’m having to lay my whole body over to one side and still struggle to make tight corners at any speeds so need to be able to fig a better set up for a better handing experience.
Any links to a purchase of ready to go upgrade appreciated
m.schuey7
- Feb 4, 2014
- Colorado Springs, CO.
- 2011 Yamaha Nytro XTX
Short track or XTX?
thetruck454
Adding curve xs skis to make the front end bite harder and a cobra track to let the back end rotate makes cornering noticeably better. I also noticed picking your line into a corner while staying on your side of the trail makes a big difference. You can't come into a corner to hot or it will push. With the curve skis and cobra track once you get to the apex of the corner, you can slowing get on the throttle and the front end will bite and the back end will come around. On slower speed corners you can either chop the throttle and use engine braking or take a quick dab of brakes at the moment you start the turn to start the back end rotating then slowly get on the throttle and it will rotate nicely. Riding the nytro fast and under control (on your side of the trail) takes a lot of energy and is definitely is a developed skill set . It still takes me a couple rides every season to get back into the swing of it, but once you do its awesome. My nytro will never keep up with my brothers apex xtx in the high speed sweepers, but in the rough and twisty low/medium speed trails it's at home.
Hooray!
- Aug 12, 2017
- Maine USA
- 2009 Yamaha FX Nytro XTX
1998 Yamaha VMAX 700 XTC
The full Bergstrom setup on the stock Tuner IIs works great on any trail, not so great in powder as we all know. I am able to enter a corner hot knowing the triple points will bite and turn and a little throttle swings the ice cobra out controllably in position to rip up your chosen line. Read how many here can't get the Tuners to work, I think Bergstrom did a lot of trial and error including the ski savers which deepen the keel, the shims, spinning the rubbers and 8" triple points (24" of carbide each ski!).... System works.
stubb111
stock skis with snow trackers (I prefer the semi-aggressive, tried aggressive....same for turning just a bit harder to turn). look into setting up your front end, a arms should be almost parallel to the ground.... a few really good posts here regarding front end set up.
Hooray!
- Aug 12, 2017
- Maine USA
This was my ski rebuild... with suspension dialed in, love how predictable the Bergstrom setup is entering corners hot and power sliding through and out. C&A's always get good reviews and are better off the groomed trail for sure. I think the 3/8" ski savers deepen the keel and with the 24" of carbide, 8" at three different angles, outer wear rod only (no carbide) you always have carbide contact... awesome.
Toominibkes
- Feb 16, 2014
I have the split rail skis on my Nytro and they were well worth the money, sled corners well
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
X2 best sled ski for the Nytro by far.
Second would be Yamaha single keel with trackers.
Stay away from any dual keel ski, once the snow builds up between the keels there’s no carbide that’s going to help with pushing in the corners.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Had split rails for years, and they are the real deal on the nytro. Made that sled handle night and day. Finished the last 2 seasons with Tuners and was surprised how well it turned with them. That chassis responds well to a twin keel ski.
Once the trails have some soft snow on them, especially in the corners better watch out. Tuners like to push. If the trails are hard the Nytro will steer like it has power steering with Tuners.
MS
MS
grizztracks
Tech Advisor
- Feb 24, 2005
- Scio, NY
Ran stock skis, Kimpex Arrow skis, Ski doo pilot skis, Split rail skis and Tuner skis. The best ski on the Nytro for aggressive riding in all conditions on and off trail is Curve skis. You don't need a whole lot of expensive metal hanging off the bottoms to make them work. The skis are designed to work with a basic set off carbides or at the most a set of Woody Slim Jim's.
Douglas Lila
- Apr 8, 2019
- Lindenhurst, IL
- 2013 Yamaha Nytro
Very interesting that the curves work so well. What were your exact carbide setups that works best for groomed trails?
I put on a set of the C&A Pro XTP with a 10" Studboy shaper bar and it turns very well but you have to turn the steering so hard that it feels like your arms are going to rip off. I was going to try some Woody's dual carbide razors to see if I could lighten up the steering. The only thing that helps me turn is when the boost kicks in and the skis fly up in the air, other than that your arms are jelly after a few miles. Has anyone else on here used some C&A XTP's and if so what was your prefered carbide setup?
4strokes
- Mar 13, 2018
- charlemont ma
- 18 winder xtx 09 nytro xtx 06 apex gt
what model sledVery interesting that the curves work so well. What were your exact carbide setups that works best for groomed trails?
Douglas Lila
- Apr 8, 2019
- Lindenhurst, IL
- 2013 Yamaha Nytro
Just an FX Nytro 121 but I do have the MCExpress turbo kit on it.what model sled
Fast
- Sep 25, 2018
Put the tuner 3's on great skijust looking to upgrade my ski from my stock set up on my 2013 nytro
radianguy
- Jan 1, 2007
- 2009 Yamaha FX NYTRO XT Express
The Yamaha MTX ski paired with a set of stud boy deuce runners have served me well on my Nytro XTX.
- 40K
