Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
What to upgrade to a great trail ski for viper great turning low darting?
this can be a loaded question as the type of snow differs from area to area in how it packs/sets up. sled suspension set up also affects a ski's performance as well.
a good ski for groomed trail that sets up well is the curve xs ski. i run them with single carbides but doolys wok well on them as well as snow trackers from what i see on here.
my local conditions look like it sets up well but it remains softer on the groomed trails. for my conditions, i tend to use an aggressive keel ski like the old yamaha mountain ski or the curve xm mountain ski. be warned though, on hard snow they can be a bear to turn.
there are other good ones out there and many members have tried most of them at some point on a viper or sidewinder.
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
I know about curve skies but the are out of business now, so looking forward other options. Mainly trail riding in the UP AREA. All trails very little off trail riding. Other options?this can be a loaded question as the type of snow differs from area to area in how it packs/sets up. sled suspension set up also affects a ski's performance as well.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
My 14 Viper with the stock cat skis and aggressive snowtrackers goes straight as an arrow and steers easy. Snowtrackers were the only thing I found that could make it turn without pushing and I tried several other carbides before them. I have a 17 sidewinder and I have tried the Tuner II's it came with and bought a brand new set of Stryke skis with snow trackers and it still doesn't track as well as the Arctic Cat skis. I know some people say the Ski Doo pilots are good as well. I'm thinking of getting some Cat skis for my sidewinder since they are a known entity to me but am curious about the pilots. Good luck!
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
Thank you for advice. Just stock cat skies nothing special?My 14 Viper with the stock cat skis and aggressive snowtrackers goes straight as an arrow and steers easy. Snowtrackers were the only thing I found that could make it turn without pushing and I tried several other carbides before them. I have a 17 sidewinder and I have tried the Tuner II's it came with and bought a brand new set of Stryke skis with snow trackers and it still doesn't track as well as the Arctic Cat skis. I know some people say the Ski Doo pilots are good as well. I'm thinking of getting some Cat skis for my sidewinder since they are a known entity to me but am curious about the pilots. Good luck!
C&A Razers with double downs or Woody Slim Jims.
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
Yes just the stock skis that came on my 14 Viper work great. Of course Mr Sled has a lot more experience than I do. You can't go wrong either way.Thank you for advice. Just stock cat skies nothing special?
Jim yamawheels
- Jan 26, 2016
- Mequon
- RX-1 mountain
I thought you did not like C&A skies? You run different one on yours.C&A Razers with double downs or Woody Slim Jims.
See you at the show
I have both. I prefer curves but as you stated they are no longer available.I thought you did not like C&A skies? You run different one on yours.
See you at the show
my old timers must be kicking in as i didn't remeber curve was gone. really liked their skis.
heard good things about slydogs too.
YamaInuk
- Mar 3, 2025
- Rankin Inlet, NU
- 2012 Nytro XTX, 2014 Viper Ltx
Agreed with curve xs were one of the best trail riding skis on what would be considered good conditions. For average trail conditions and any off trail riding I recommend slydog. My only experience is with the 8" powderhound but IMO they provide the best traction/light steering ratio. Aside from the bolt length, they use the same ski rods as c&a so there are some great options. Woody's makes ski rods specially made for slydog. I've tried C&A mtx & xtx but they make the already heavy steering sled..... heavy. I'm on my 4th pair of slydogs (4 different sleds) since the 1st time I've tried them.
ishpeming fan
- Feb 5, 2017
- Bristol WI.
- 2019 ZR RR 8000
Curve with leading edge and 6inch shaper bars. you can thank me later.
just keep searching market place and swap meets until you find a set. Barn of parts may have some as well.
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I've had good luck with the Skidoo Pilot 5.7s. Easy retrofit. It also means I can share carbides with the rest of my group.
AftonJay
- Oct 23, 2012
- Northern Michigan
- 2005 Warrior, 2009 Nytro XTX and Arctic cat puma for the kids
- Afton Mi
I have SlyDog attacks on mine and it tracks straight as an arrow.
Cable810
- Jan 25, 2018
- Rogers City
- 2015 Viper MTX MPI 190
- Rogers City Mi
I have the slydog attack on my viper mtx. Great for both on and off trail. I mostly ride off trail and only run trails to and from play areas.
