Theblackbullet
Hey guys, I'm hoping to get a little input on my next project. I'm currently running a 1.25" Ripsaw with studs on my 136" M-10 RX Warrior and it needs to be retired before something bad happens.
I do 75% medium-aggressive trail riding and 25% off trail/ back country riding. With that being said, is there a better option then my current Ripsaw w/studs, like a different brand, or a bigger 1.5" lug? I have read a few things that told me a 1.5" with no studs will hook as well as a 1.25" with studs. If that is true I would be on board to take the risk out of putting a stud through my heat exchanger.
I only put on 500-1000 miles per year, so the real longevity that I'm worried about is dry rot, and that is why some of my current studs have begun to fail and rip out.
Thanks in advance for the feed back
Indy
worth a bumb
sledheadgeorge
1.6" Ice Cobra
http://www.tracksusa.com/Ice-Cobra-...1&browse=-47153&shopBy=-13144&catalogId=-3693
or
1.22 Ice Attack
http://www.tracksusa.com/Ice-Attak-...0&browse=-47152&shopBy=-13144&catalogId=-3693
I use the Ice Attack and it works well both on and off trail.
or
1.22 Ice Attack
Theblackbullet
1.6" Ice Cobra
or
1.22 Ice Attack
Does the 1.6 fit with stock drivers?
sledheadgeorge
I'm not sure. Better check. The pitch is fine and the drivers will turn it. Just not sure about clearance. I bought the ice attack last year for my XTX. I would have preferred the 1.6 Cobra for better off trail performance.Does the 1.6 fit with stock drivers?
RX1Anola
I put on a 1.5 Intense this season on my RX-1 this year. Also stretched it to 136". Amazing hook up coming from a 121" 1.25" ripsaw. I did have to take out my stud protectors to make it fit.
Theblackbullet
Thanks for the input. I think I'm down to the 1.5 intense or the 1.6 ice attack. It will probably go on this summer.
rx12004
- Jan 4, 2017
- iles-de-la-madeleine, québec
- Yamaha rx1
just take a look to composit t-38 . It a 1.5 lug with agressive pattern great hook up
