Cable810
- Jan 25, 2018
- Rogers City
- 2015 Viper MTX MPI 190
- Rogers City Mi
I've looked and looked and haven't found anything on whats needed for the big wheel kit so I'm going to ask. I'm assuming that the shaft is bigger for the bigger wheels?!?! I see JT offers a kit but I'm looking at SlyDog 10" wheel.
I'm assuming like I said I need a bigger shaft to run the 10" wheels or can I use the original shaft?!?!
GR8BBQ
- Mar 23, 2018
- Hamlin, NY
- 2017 Yamaha SRViper X-TX SE
2017 Ski-Doo Blizzard 900 ACE
2001 Yamaha SXR 700 Triple
1995 Polaris Indy Lite
I'm not sure you could use a wheel that much bigger without relocating the axle.
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
The J&T Kit is 1/2" larger than stock on the 137" skid.
You'll need an offset axle for the 10" wheels.
Be sure to post pictures of what you land on.
Tricked Toys - Snowmobile Accessories - Home Page
www.tricked-toys.com
Cable810
- Jan 25, 2018
- Rogers City
- Rogers City Mi
I might just go with the original size wheels then. I've found a kit from ice age but not spending almost 400 bucksThe J&T Kit is 1/2" larger than stock on the 137" skid.
Tricked Toys - Snowmobile Accessorieswww.tricked-toys.com
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
You are correct. You will spend substantially more.... not spending almost 400 bucks
Yamarus
- Oct 4, 2021
- Russia
- Russia
- Yamaha Sidewinder B-TX LE 153
In Russia, local companies produce and sell wheels 10". I have a BTX 153. There is a desire to install 10-inch rear wheels. Some install 10-inch and even 11-inch rear wheels in the form of TKI on the brp. It's expensive for me.
I'm worried about whether the 10-inch wheels will touch the rails. Now I have everything in factory mode, it's about 8 inches. And is it possible to install 10-inch wheels without replacing other parts?
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
No... is it possible to install 10-inch wheels without replacing other parts?
View attachment 168678View attachment 168679View attachment 168680
Yamarus
- Oct 4, 2021
- Russia
- Russia
What details do I need to change to install 10"? You may need to change the variator settings.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
This should get you started.
10" wheels will require an off set axle kit.
Yamarus
- Oct 4, 2021
- Russia
- Russia
Our guys sell wheels with a set of axles with offset.
It's unclear to me if the 10-inch wheels will rest on the track.
Катки для снегохода увеличенные, ролики для снегохода 10 дюймов, каток AC, каток БРП
Ролики изготовлены из материала с низкой адгезией, у которого практически отсутсвует влагонакопление, исключено налипание снега, грязи и тп. в отличие от других материалов, которые применяются для изготовления подобных комплектов. Рабочий температурный режим от -250 до +80С
a911tuning.ru
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Looks like a pretty decent kit.Our guys sell wheels with a set of axles with offset.
It's unclear to me if the 10-inch wheels will rest on the track.Катки для снегохода увеличенные, ролики для снегохода 10 дюймов, каток AC, каток БРП
Ролики изготовлены из материала с низкой адгезией, у которого практически отсутсвует влагонакопление, исключено налипание снега, грязи и тп. в отличие от других материалов, которые применяются для изготовления подобных комплектов. Рабочий температурный режим от -250 до +80Сa911tuning.ru
Give them a call directly. They will be able to answer questions better than anyone on here.
And please post a picture of your new set up!
earthling
the site shows an offset axle.
sabrecat
Vendor
- Nov 7, 2013
If you go any bigger then our 8.5 wheels you will have to have a offset axle for sure.
JT has everything in stock.
the 5.5 inch suoer duty idlers are in stock now. Very durable wheel that will run on stud heads. Comes with lager bearings or stock size.
for the 2012-18 the 8.5 stealth kit is going to work best and cost less then many other brands.
larger diameter axle, heavy duty Avid wheel with larger bearings. ( twice as big as stock) billet axle adjusters to replace the cheap cast ones.
stops wear on the hyfax at the rear, Many customers are seeing over 10.000 mile before bearing change.
The 2019 and newer kits come with four 8.2 Avid wheels with larger bearings and will stop the drag on the ends of hyfax, Comes with 5 aluminum bushing and spacers to replace all the plastic parts. This kit was designed to reuse the stock axle. The stock axle is very strong at about 13 inches long and 1' diameter the full length. This reduces the cost of this kit over the older models.
for the 2012-18 models if you dont want the outside wheels get the heavy duty Trihub replacement. Come with heavy duty wheel with the larger bearing. The larger diameter axle with the billet axle adjusters. Can beat the price of this kit for reliability.
www.jtatv.com
www.jtatv.com
