stgdz
- Mar 27, 2021
- Buffalo MN
Anyone run the pro-dual rate twisted springs that hygear sells? It's the one where you can adjust the middle collar on the threaded section.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I have run them on my Nytro. Get the Pro version with the threaded collar. You can really fine tune with those.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Got the exit shocks through Ian for my sidewinder rtx. The valving that exit sent was no better than factory if not worse. When I had Ian redo them they were much better! I do plan to get an elka stage5 center shock tho so I can get my wheels back on inside of rails and I feel it’s much higher quality shock.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Why did you have to move the inside wheels outside? I though I have seen pics of center shock mounted upside down with reservoir. Didn't noticed people moving wheels...
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I put a set on late this winter. Only put maybe 200 miles on them. Front end sits lower so I had to adjust my center spring to match. Cornered flat and the chop was pretty good. Have not had them in the big rough trails yet.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Exit center shock has the resivoir in the way. I prefer way the elka /axis works for center better.Why did you have to move the inside wheels outside? I though I have seen pics of center shock mounted upside down with reservoir. Didn't noticed people moving wheels...
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Thanks for the reply. I wonder if the QS3R center would be in the way too if upside down? That was my plan...
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Qs3 mounts resi up. There’s no way to flip the shock as the eyelet for the cross shaft vs the bolt are entirely different.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
So your saying QS3 eyelet are different than QS3R?
Canondale had received this from one of his client. I was planing to keep the wheels inside and use the stock spring on the SE...so no go?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
They are mounted the opposite direction on all the ones I’ve seen
- 6K
