BryKlu
- Nov 1, 2017
- Presque Isle, Wisconsin
- 2010 Vector LTX GT
So I had to replace all the fluid in my brake system on my 2010 Vector this year. I had to fill the reservoir and let the fluid settle before any would come out the bleeder. I pumped a few times and held, bled one side, pumped, the other, back and forth and a lot of fluid was ran through but still no brake pressure or uniform piston function. Any tips from the forum?
sxr70001
- Dec 4, 2010
- Michigan
- Sidewinder LTX SE
SR Viper RTX SE
I have seen on a quad that the master cylinder on the handlebars can go bad. Ordered a used one off ebay and it worked perfectly. Just an idea
BryKlu
- Nov 1, 2017
I am going to try a brake bleeding vacuum as well and rebuild the caliper.
72Gran
- Jan 25, 2009
- 92 Vmax 4
21 Sidewinder LTX GT
98 Venture TF
Sometimes an air bubble will get stuck at the fitting on the master. Try pumping and cracking that fitting first. You can also try to force the calliper pistons open which will basically send the oil back into the master and reverse bleed the system. A c clamp will work for this and be sure to use something so you don’t damage the piston.
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
Snowmobiles can be a pain to bleed sometimes. The vacuum bleeder should help. you can also fill the reservoir and leave the cap off, crack bleeder screw and let it gravity bleed. Takes a while but works. Also pumping the fluid in from the bleeder screw UP to the reservoir does the trick. Any of the above will work better than the conventional pump/bleed method
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I use a vacuum bleeder and have no trouble. It was worth the investment especially if you have other toys like motorcycles, 4 wheelers etc.
Those small systems can really be a pain to bleed otherwise.
BryKlu
- Nov 1, 2017
Sweet! I picked one up for my enduro I just bought so I'll just have to use it on the Vector. Thanks everyone!
Snorunner
- Jul 17, 2018
- Deerwood
- 2016 Vector XTX
2017 Vector XTX
2001 Arctic Cat
I don’t know about the power sports world. But in the Automotive world. New master cylinders need to be bench bled. This would involve filling the master cylinder. Putting it in a vise. And pushing it in. With fingers blocking the ports. Several pushes. With fingers blocking the ports on the return strokes would solve this. Hope this
Helps. I have used gravity bleeding in the past. Works. I have never used a vacuum bleeder. So I can not relate to that. Just food for thought!
