RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Ben from TD had mentioned earlier that Woodys Yamaha has this figured out and it requires machining of the pocket and I think the sheave. Anyone know any more about this or them in general?
Woodysyamaha Is actually woodys performance center in topshahpm maine.
Keith Woods is the owner. He has been drag racing and tuning sleds for years.
Held a few speed records as well
He knows his #*$&@ and is more than happy to talk if you ask him a question.
ApexGTman
- Jan 8, 2006
- Newfoundland
- Hers - 2017 Sidewinder XTX LE
His - 2015 SR Viper RT-X LE MPI Turbo with Ulmer Stage II Clutch Kit
2012 Apex SE
2006 Apex GT, Stage 2 Ulmer Clutch Kit, Ulmer Stealth Mod Air Box, 144 1.325" Woody's
2003 - RX1
1998 - SRX
1993 - Exciter SX
1992 - Exciter II
Any Pics?I took 3 flat washers and sanded one edge flat so they would fit under the helix. I then put them on the surface grinder and took them all down to 0.06 so they were identical. They are placed on the 3 posts underneath the holes in the helix. You have to make sure the flat spot stays to the inside when tightening the helix so they fit properly under the helix. I also used some blue loctite on the post threads. With the shims it's really close getting a thread to protrude through the nylon portion of the flange nuts.
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Is that this one?
http://www.woodysyamaha.com/m/index.htm
- Apr 14, 2003
- Hessel, Michigan
Any Pics?
Hope this helps you....
These 2 pics are just a reference to what you can do....but machining the secondary or using a thinner wire spring is a much better option... IMO
RTX
- Mar 31, 2005
- 2014 viper rtx
2006 apex rtx
Is that this one?
Yes it is. Topsham maine
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Popped another gates 8dn Gates carbon today. 100 miles new belt. DONE with that belt. Going 8jp as it's the Only difference with other guys that have almost identical set up as myself. Something is not right with that belt. I never went over half throttle first 35 miles on the belt today. As I wanted to break it in right. Blew it at 60 mph. Not a clean break today.
1100saber
- Dec 17, 2016
- northern ontario
- 2017 Sidewinder LTX-SE
- AlliedPerformanceShoppe@outlook.com
I never had any luck with those carbon belts on my 1100's. I did have great results with XTX belts. I'm gonna try one for this sidewinder soon. I have heard the compound hardness is a compromise between the 8JP and 8DN
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
That sucks!Popped another gates 8dn Gates carbon today. 100 miles new belt. DONE with that belt. Going 8jp as it's the Only difference with other guys that have almost identical set up as myself. Something is not right with that belt. I never went over half throttle first 35 miles on the belt today. As I wanted to break it in right. Blew it at 60 mph. Not a clean break today.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Had great luck in past with XTX on my cats in past. Has to be carbon belt. I double checked everything before coming up. Offset etc. secondary machined pocket. It's a head scratcher for sure. Has to be belt. Or a bad motor mount or something out of whack.I never had any luck with those carbon belts on my 1100's. I did have great results with XTX belts. I'm gonna try one for this sidewinder soon. I have heard the compound hardness is a compromise between the 8JP and 8DN
jpr-ltx-dx 2015
- Sep 21, 2014
- sr viper ltx dx
how was the temp outside when you did blow it?the reason I ask is the 2 belts I did blow,it was around 0 cel outside and I could feel how hot it was in side the hood of my sled.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
It was cold. BUT I have a frog skin vent that I installed right in front of clutch. It's gotta be the belt material.how was the temp outside when you did blow it?the reason I ask is the 2 belts I did blow,it was around 0 cel outside and I could feel how hot it was in side the hood of my sled.
kylechargerrt
- Dec 8, 2013
- Scotland Ontario
- 2017 YAMAHA SIDEWINDER LTX-LE
1998 MACH-Z
900 miles now original belt still looks good. Not a whole lot of long pulls as lakes are still sketchy.
Sent from my SM-G920W8 using Tapatalk
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
UPDATE. did 170 miles with 8jp. No blown belt. Had three fairly hard pulls on it. AND held it at 80-90 for 1-2 miles. My max rpm went up considerable. I was at 8800 give or take with Gates carbon 8dn. Now it's pulling 9300-9400. I don't now what popped two carbon gates belts. IS IT POSSIBLE that the gates carbon is too sticky? It's almost like when I blew the two belts the belt was hanging up in the secondary. As I was off throttle then back into throttle. Did a few miles this am. Hammered it once decent. No belt blow. After two a guy just waits for that bang.Popped another gates 8dn Gates carbon today. 100 miles new belt. DONE with that belt. Going 8jp as it's the Only difference with other guys that have almost identical set up as myself. Something is not right with that belt. I never went over half throttle first 35 miles on the belt today. As I wanted to break it in right. Blew it at 60 mph. Not a clean break today.
dsimonRX1
- Dec 17, 2003
- Cascade,Ia
- www.american-iowa.com
That's a huge jump in RPM for just a belt change.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yes I actually think the gates carbon was faster also. I could pull skis at like 55-60 mph. Hoping that was the issue. I got like 205 miles on stock belt now. Gotta check things over when I get home tomorrow.
- 10K
