jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
my bad ...hurricane stm 83g weights...270 flash with quite trail exhaust.... no studs... and I'm 250 lbs..... wasn't going fast as such but was on the fuel coming out of a lazy turn....pullin hard and boom ....plastics gone...it might help if you post your setup...your weight...power level and driveline mods in detail...
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Is anyone here running a belt adjuster. ?
I really think we are running the belts too tight. Quick rule is no higher then flush on the secondary.
Speaking from experience.
Belt deflection has no effect on anything past engagement. Hence, no effect on whether a belt blows or not.
KnappAttack
- Feb 19, 2004
- Welch MN
And the rest of it? Drive spring, driven spring, helix, belt & offset at least?
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
all stock... 8 jp belt
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Yap.
Been there you need to dig in a and see what's going on with these clutches. There's a few known issues on this thread.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ok that makes sense. I was thinking it would be too tight right throughBelt deflection has no effect on anything past engagement. Hence, no effect on whether a belt blows or not.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Stock weights with a 270 flash could be a problem Houston.all stock... 8 jp belt
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
He does not have stock weights, look up a few posts...Stock weights with a 270 flash could be a problem Houston.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Oh my bad I see he’s running stm’s. Guess his belt failed with a snap, says it looks like it was cut with a knife. Usually that’s something binding in the secondary. How do your rollers look? Did it break at high speed or riding in the corners?
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
probably 30-40 mph... coming out of a corner and got on the fuel...
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Jagger did you hammer the brake going into the corner? (That’s what I do anyway!) if so with the stock secondary spring, the belt will become unloaded. then when you hammer it the the primary has nothing to squeeze right away and builds up speed until it smacks the belt, grabbing it like Michael Jackson at a orphanage. This shock loads the heck out of the belt. A stiffer secondary spring will help the secondary to close up faster preventing this.probably 30-40 mph... coming out of a corner and got on the fuel...
An 8dn belt will help with this also as it will slip a little when hammered instead of grabbing immediately. If your worried about groving try a xs825 it’s not as hard as the 8dn.
M2C
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
I've blown lots of belts just the same. I believe it's a buildup of heat when riding and it just can't take the WOT torque when coming out of the corner when that hot.probably 30-40 mph... coming out of a corner and got on the fuel...
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
ClutchMaster probably nailed it. Maybe thats one reason for me not blowing belts. I like to glide into corner and let the clutch pull me down which helps plant the front... Then throttle through. Now I'm just old & slow. I use my brakes twice a season. Wether I need to or not.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Soupy you said you were shredding belts not snapping them, usually a different cause. Heat usually shreds belts shock loading snaps them. Not always but usually.I've blown lots of belts just the same. I believe it's a buildup of heat when riding and it just can't take the WOT torque when coming out of the corner when that hot.
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
will my belt snapped rite into..... there was no other belt parts dwn inside....cleanest break you could ever imagine....i was expecting to see a million pcs ...
- 10K
