I had the same problem last year, they had my msd pump wired backwords, so it sounded like it was working but it was actually fighting against the stock pump and the sad thing was that boondocker did my install. After I switched the wires it worked great, but make sure you adjust your fuel pressure regulator, since when you adjusted it with the pump running the wrong way, it will now be extremely rich.
