hauler
Do they have any????
tapex_07
- Feb 15, 2009
'07 Apex RTX SC2 MPI 128x1
I saw theres a built in EGT. But I don't recall boost or afr?
None.. they say none is needed. If you cant adjust it why have a gauge to tell you what its doing? AFR reading would be adjusted by the on board computer and it has EABC type adjuster for boost so the boost is preset.
Can the ECU be modified to allow more boost?
Time will tell, I am sure someone will crack it.
If the guage is like the Viper guage which it looks like it is. You can go into diagnostic mode and I will bet the boost reading will be available from the MAP sensor. Will require some math but will be there. Not sure if the new electronics will use a wideband O2 sensor but would be nice since current is not.
smokum613
- Dec 14, 2015
- Edwards, Ontario
- 2011 Apex SE w/Yamacharger
http://www.ty4stroke.com/threads/mcxpress-sidewinder-upgrade-kit.141056/
Sorry, it had to be removed into ads holding.. He is no longer an advertiser and this needs to be addressed.
