Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
Which ones did you order? They list of like 15 different numbers.Just orderd a set! Have a hid upgrade kit in mine now but am not happy with them the cut off point for high and low beam are so far off low has to be on ground right in front of sled otherwise high beam is in the trees.
Deeppow16
- Oct 19, 2015
Nevermind, I saw your other post pop up. I just ordered the H4's. Pretty excited about these. They look like they work awesome.Does the nytro run a B4 bulb?
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Awesome! I misunderstood the description then. I thought it was 100 watt per bulbYes kits plug and play. 50watts per bulb no different then stock halogens
Sent from my LG-H831 using Tapatalk
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
I ordered a set as well. Can't beat the price!
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Steeler jim and deeppow i had to adjust the headlight down 1 1/4 full turn. Now its perfect
RobWarrior
- Oct 4, 2008
- Western Ma
- 09 FX NYTRO RTX
Pretty sure 50 watt led only uses about 7 watts of power? They should draw far less than halogen lights...great for your Stator.Awesome! I misunderstood the description then. I thought it was 100 watt per bulb
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Pedros, How long from the time you ordered until you received it. I know it shipped but don't know how long it takes to cross the border
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Mine was 4 days from order date. But was in Canada. Should give you tracking info
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Great info pedros83...
I just ordered a set
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Unfortunately this isn't the case. A 7 watt led may equal a 50 watt or so incandescent bulb. These will draw the 50 watts as advertised hence the need for cooling fans on the back due to the high heat they generate. However, 50 watts from an LED should be far brighter. The average car headlight is around 3100 - 3300 lumens if I remember right. The 16000 lumens this kit claims should be more than twice as bright as normal headlights.Pretty sure 50 watt LED only uses about 7 watts of power? They should draw far less than halogen lights...great for your Stator.
Deeppow16
- Oct 19, 2015
Ok thanks I'll remember that when they get here.Steeler jim and deeppow i had to adjust the headlight down 1 1/4 full turn. Now its perfect
foefame
- Jan 2, 2015
- 2008 Yamaha Nytro rtx
So if I have the HID kit. can I just replace the bulbs with these LED bulbs
pedros83
- Nov 19, 2015
- Blackstock, ON
- 2010 Nytro XTX
Yes they plug right into stock h4 harness. No ballast nothing. 5Min install.So if I have the HID kit. can I just replace the bulbs with these LED bulbs
foefame
- Jan 2, 2015
I have the HID kit with ballasts. Can I just replace the bulb in that system with the Led bulb???
SteelerJim
- Dec 6, 2010
- Rockton, Pa
- 2011 Nytro XTX
Yes. They don't need ballasts so you can remove thoseI have the HID kit with ballasts. Can I just replace the bulb in that system with the Led bulb???
