DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
- 2015 SR VIPER MT-X W/MPI TURBO. 153”
I just put a replacement track on my 2015 MTX. My first endevor tearing into the Viper that deep, I learned a lot about he machine!
I have the chain case all reassembled, leaving me with just the brakes to reinstall. I did not split my caliper, just unbolted the 3 bolts from the frame and pulled the caliper and rotor off the shaft.
To reinstall the brake assembly is really holding me up. I can't seem to wiggle the caliper onto the shaft with the rotor in it, and also can't get the rotor on the shaft with the caliper already on the shaft.
What should i do? Split the caliper, and try to install that way which will need fluid bled after? or is there a way to get it all on the shaft in one piece I haven't found? Biker Mike on YouTube got it all on without splitting the caliper, but not sure how. Any insight is greatly appreciated!
It will go sometimes the spline get marred and won’t go unless you mess with it. Brake pads are off correct?I just put a replacement track on my 2015 MTX. My first endevor tearing into the Viper that deep, I learned a lot about he machine!
DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
Pads are off yes. So I just need to hold my tongue just right and it should goIt will go sometimes the spline get marred and won’t go unless you mess with it. Brake pads are off correct?
Yes. Sometimes you have to swear at it and hold up on the axel at the same time. I’ve been there.Pads are off yes. So I just need to hold my tongue just right and it should go
DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
well I have plenty of those lined up haha. Thanks for your input I will get after it!Yes. Sometimes you have to swear at it and hold up on the axel at the same time. I’ve been there.
DS22-HuberWoodsME
- Dec 5, 2020
- Easton Maine
Update:
All good now! I did end up splitting the caliper because the pistons came out just a bit too far to allow for the space of the rotor/shaft/pads to tie in together. It was good to inspect the caliper anyway. The assembly slid on nicely. Now to do a little brake bleed with my new brake bleed kit from Harbor Freight (Likely Junk) and we have stopping power!
Thanks to this great group as always with helpful tricks of the trade.
Next time you split the caliper you pull pads And then pull lever to bar and zip tie it down and you will loose very little fluid and most likely not have to bleed it much.Update:
HUS457
- Dec 30, 2020
- Cape Breton, NS
- 2015 Viper S-TX-DX - Traded
2023 Sidewinder LTX-GT
I loosen the plastic shroud under the rotor too, which gives me more wiggle room to get the rotor on & off. That, and reach up into the tunnel and push the driveshaft up a little bit.
- 6K
