JAZZ04RX1
- Dec 28, 2003
- Illinois
- 2016 SR Viper LTX-LE
Just changed out my stock brake lever with the Skinz short heated brake lever. The installation sheet notes to not let the piston come out of the lever assembly. I thought I did that but I must have let the piston slide out enough to cause a leak. Once I installed the new lever the piston began to leak. I also feel the brake feels a bit soft. Looking for some help on how to stop the leak and get my brake back to normal. Did I damage the seals for the brake lever piston and also ingest some air into the system?
Any help would be greatly appreciated.
snowfever27
- Jan 7, 2015
- Vermont
- 2015 Arctic Cat XF7000
2009 Yamaha Nytro XTX (sold)
2007 Yamaha Phazer FX (sold)
2005 Ski-Doo MZX 800 Adrenaline (sold)
2003 Arctic Cat F7 EFI (sold)
2007 Yamaha Attack
2009 Polaris 600 Dragon SP
- Vermont
I would bleed your brakes. You may have folded the seal over when you pushed the piston back in. I’d take a real close look at it.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Hays brakes...
Why didn't they put a snap ring in there to keep the Piston from coming out too far!
I haven’t seen a rebuild kit but maybe try calling Hayes directly.
PAvector
- Feb 24, 2007
- Pennsylvania
- 2014 Yamaha SR Viper
Make sure you remove the oil buildup from under the rubber piston cover from the install before determining it’s still leaking. I had this issue when installing the Polaris lever. My brake is also now soft, will try to bleed it.
Looks like they make some nice products. We just got bottom line. If you get new Master Cylinder I would try the new one from the 19's.
https://hayesperformance.com/products/snowmobile/
https://hayesperformance.com/wp-content/uploads/2018/08/Hayes_MasterCylinder_Radial.pdf
JAZZ04RX1
- Dec 28, 2003
- Illinois
PA looks like that is the issue with fluid in the piston boot. Made sure the boot was seated back on the piston properly last night and checked it tonight no fluid that I can see now. Even after pumping the brake several times. Now bleeding the brake would be my next step here.
Anybody have a recommended bleeding procedure? Never had to do this on any of my other sleds.
Love the new lever and gets really hot to the touch may need to put a switch on it!!
Thanks for all the replies love this forum.
Just try bleeding normally and if that doesn’t go well back bleed it.
