Well my 06 apex gt left me out on the trail again. The shock tabs on rear pivot arm broke off. I had to remove the shock and put a stick between rear pivot arms and rail just to tow it. Two weeks ago one of the rear wheels came off and the suspension adjuster bolt ripped the track like a can opener. When I had the suspension out I noticed some cracks in the front pivot arm and I replaced it with the new reinforced 08-09 arm does anyone know if the rear arm was redesigned.
THKSNOW
Smooth Operator
- Aug 11, 2006
- 2013 RS Venture GT
I can only assume you only had 3 rear wheels and lost the "odd side" outside wheel. If you put the 4th wheel in when you put it back together, it probably will save your track from damage if (when) it happens again. That 4th wheel saved my azz in the middle of no-wheres-ville. One of outside wheels was gone, just the inner race still on the shaft, able to limp back at 20-25mph.
