Weapon X
well they would be also installing the pivot arm that I just slapped on my sled. Thats why its so expensive.
Check out my topic from break
http://www.ty4stroke.com/viewtopic.php?t=98241
Lite
After seeing where the problem was(in pictures and so on in this topic and others) I grabbed my led-light and went to take a look.
Guess what, the crap was broken in a weld, where the front shock is mounted, just closer to the axcle. Will add some pictures later.
Is this covered by yamaha since it's an known problem?
yamahabuyer
- Mar 4, 2010
- Greenwood, WI
- srviper and apex
- greenwood wi
does anyone have the part number for this updated kit. I just broke mine this last weekend. I rewelded it and braced it but thats just to get me threw the rest of the year. called my yamaha dealership and they had no clue what I was talking about. Thanks
TIMSMXZ
part# 90891-50149-00
buddhahead
- Mar 21, 2008
- Mid-Michigan
- www.shawwinkler.com
Mine broke this weekend. What is the name of the part? This was a notorious problem on the 07 and 08 models. Mine is the steel, not the aluminum. Does anyone know if this is covered under YES?
blueironranger
- Feb 3, 2009
- Iron Range MN
- 2014 Viper XTX
2009 Phazer MTX
the continue to strengthen the front arm every year, I know the P/N changed EVERY year from 2007 to 2010. I haven't looked to see if the 2011's have a different P/N than 2010. The 08' was slightly stronger, the 09' arm looks beefed up quite a bit, the 2010 arm is a even more beefed up. If you bust a front skid arm find a used 09' or newer or buy an new 11' Arm. I think 08'+ have the billet aluminum pivot.
Weapon X
the pivot arm part number will have -03 at the end not 00 cuz 03 stands for third generation. This arm started on the 2010 Phazers and is also on the 2011 phazers.
Weapon X
Yours is only a '07 problem you will need the updated parts to go billet. Most likely too late on the warranty.buddhahead said:Mine broke this weekend. What is the name of the part? This was a notorious problem on the 07 and 08 models. Mine is the steel, not the aluminum. Does anyone know if this is covered under YES?
snofreak500
Do the 08's tend to have problems or no just want to know if anyone has had an issue with their 08's ??
buddhahead
- Mar 21, 2008
- Mid-Michigan
Weapon X said:Yours is only a '07 problem you will need the updated parts to go billet. Most likely too late on the warranty.buddhahead said:Mine broke this weekend. What is the name of the part? This was a notorious problem on the 07 and 08 models. Mine is the steel, not the aluminum. Does anyone know if this is covered under YES?
Why do you say that? I still have a year or 2 on my YES program. I know its not a recall, but a tech. bulletin. Limited time only?
Weapon X
Ya alot of guys on here are sayin there dealer has let them know that there was a time limit on '07 issues, if you think you got coverage on this part get it checked out
buddhahead
- Mar 21, 2008
- Mid-Michigan
I will find out tomorrow. Thanks. One would think that Yamaha would send something out warning owners that it would be covered for a limited time. I havn't done any mods to it because of the YES
Weapon X
Not gonna sugar coat it some dealers will fight for ya and some only look on sellin machines.
buddhahead
- Mar 21, 2008
- Mid-Michigan
I understand that completly. Doesn't make sense but I know there are dealers like that
